Question about Majesco Jaws Unleashed for Windows
Can't install jaws unleashed it says installer interupted
I've got all the recomended specs, except I'm running vista. I checked the site for the game and it said that it should work fine with vista. any solutions? I don't know how to change reg keys, so that one doesn't work for me.
  • 3 more comments
  • MisterFreeze Jan 01, 2009
    i got the same prob installing the game with visa.. any solutions?
  • Anonymous Feb 21, 2009
    me too
  • Anonymous Mar 26, 2009
    exact same prob, also on vista D:
  • Anonymous Apr 18, 2009
    I have the exact same damn problem
  • Anonymous Apr 30, 2009
    same thing so annoying i heard you might have to get winxp
Can not install a game I purchased
If the specs for the game are not equal to or less then the computer specs then you will have an issue
If the computer specs are greater
  • Does the installer cut out unexpectedly? try to
    1. Run installer as Admin
    2. Run Install in compatibility mode ie set at a OS compatibility for game
    3. Check if being blocked by any Anti virus/Security Software, maybe suspend and try install normally or try 1-2 again
  • Does the installer give a message? - take snapshot and post here so someone can point you in right direction
Mar 25, 2015 | HP Pavilion Computers & Internet
What is causing igi starting error?
There are so many reasons why the fatal exception error has occurred. First, your video card maybe has below specs and need to upgrade. Second, maybe you didn't install a direct x in your computer that's why games didn't run successfully. Last, some files are corrupt so the game will not run properly. Solutions:
First, upgrade your video card to a higher spec.
Second, try to install a direct x in your computer. This is the link to download DirectX
Third, try to uninstall the game and reinstall it again.
Aug 17, 2011 | Computers & Internet
I am trying to play rise of Rome on my PC which is running windows 7 and it says it cannot connect to server. All aspects of the game work fine except that, and it works on the other two computers on the...
simply right click on the .exe (ie. game file) select properties.> Select compatibility tab.> Check the "run this program in compati........"> Select xp as you said it works fine on xp.> Click OK
There u go have fun :)
Jul 05, 2011 | Microsoft Age of Empires: The Rise of Rome...
I've uninstalled and re-installed Blitzkrieg Anthology with my CD-ROMs and I am not able to play the game, everything loads fine but when I try to play the game the screen map does not pop up, gives me...
Try updating your video card drivers. However, according to the specs, it's not supported for vista.
Vista site is equally unhelpful.
http://www.microsoft.com/Windows/compatibility/windows-vista/Details.aspx?type=Software&p=Blitzkrieg%20Anthology&v=CDV%20Software%20Entertainment&uid=&pf=36&pi=6&c=PC%20Gaming&sc=Strategy&vd=all&os=64-bit
Had a quick browser on the forums. Have you tried this vista dual-core patch?
http://bkpforums.com/phpBB2/viewtopic.php?f=58&t=3275&p=108961&hilit=screen+map+vista#p108961
Best of Luck
Jun 11, 2011 | CDV Software Blitzkrieg for Windows
Hi, my AoW: Direct Action won't work on my vista 64-bit. I have tried some recomended solutions but nothing works for me. please help me :)
There is a chance that this game simply isn't supported by vista 64-bit. Check the games sysreq. (system requirements)
Feb 02, 2011 | Atari Act of War: Direct Action for...
Graphics card wont work after os change
if u have downloaed drivers those are not supporting then you have to un-install graphic drives and try againe it will work or install menualy
1 go to Divice manager
2 setlect graphics
3 run that it will ask you for run software select that foloder where is your deivers and run menuly
hope fully it will detact
Apr 20, 2010 | Computers & Internet
I have the sims unleashed pc game and have had it for a few years now and the back bit must of fallen out and now i have no serial number to install it again can you please help me
you need to find your serial number of the game, but if you cant, and you dont know how, you can try find in a google, but
here is unleashed code = 1501-6357703-2153908-4207
i hope that you didnt download it :)
enjoy
Feb 24, 2010 | Electronic Arts The Sims Unleashed for...
Age of sail 2 failz on vista runs on weaker XP computer
If you are running Vista, before you consider downgrading to XP, find your privateer.exe file and right click it. Once the page is displayed, left click on compatibility. Then check the Run this program in compatability with... Click the button below and scroll until you find XP. Click it and then click Apply to save it. Then click ok. That should enable you to run the game on Vista. If it doesn't something is wrong with your operating system, not the computer.
Nov 29, 2009 | Global Star Software Age Of Sail 2:...
My Gta.exe has stopped working
Hi buddy please delete the gta_sa.set file from the User Files folder.
If this doesn't work and your Sys specs is this
Intel Pentium M 1.86GHz
ATI Mobility Radeon X700 128MB
Windows Vista Ultimate
and you are using crack then:
Click start>Right click "my computer">Properties>Advanced> Under performance hit 'settings'>Data execution Prevention> hit "turn on DEP for all programs and services except those I select".
I hope this will work...
Sep 22, 2009 | Rockstar Games Grand Theft Auto
Majesco Jaws Unleashed for Windows Logo
464 people viewed this question
Top Majesco Video Game Consoles & Games Experts
comandomcl8
Level 1 Expert
Tafi Nami
Tafi Nami
Are you a Majesco Video Game Console and Game Expert? Answer questions, earn points and help others
