Question about HP Pavilion dv9005us Notebook
Unable to connect computer to tv by pressing (fn+f4)
HP. dv9005us was returned to HP for warrantee repair. Prior to that I was able to view my laptop on my tv by pressing (fn+f4). When I press these keys together nothing happens. Have I lost a driver? If so how do I replace it.
I would like you to tell witch keys i should used to get hp pavilion dv9000 pc lobtop screen to display on a samsung plasma monitor
I'm assuming you are connecting the laptop to the plasma screen with an HDMI cable. If you have done so, then have both the TV and laptop turned on. Log into the laptop with an account. After you have logged in, you can press the function key (Fn) and usually its F4 (the key has a picture of a square, this represents the external display connection) at the same time. The plasma tv should display what is on the laptop.
So, Fn + F4 should work.
May 21, 2011 | HP Pavilion dv9000z Notebook
Tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 | Computers & Internet
Tip
How to use F1, F2 ?..Function buttons on Acer laptop.
For those who do not know how to use the F1, F2, F3..... buttons on Acer laptops, here is an opportunity for you to know.
>To put your Acer laptop on stand-by or to view shut down options, Press and hold Fn button on your keyboard, (without leaving it) then press F4 (Fn + F4).
>To make your Acer laptop be on sleep mode, Press and hold, Fn button, then press F6 (Fn + F6).
>To lock your Acer laptop's Touchpad, press and hold Fn button, then press F7 (Fn + F7).
>To put your Acer laptop on mute Press and hold Fn button, then press F8 (Fn + F8).
>To close any page on your Acer laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Oct 23, 2010 | Computers & Internet
When i connect my notebook to LCD TV with hdmi port, screen goes black but on TV "No signal" message appear and can`t view the monitor on TV. I have windows XP sp3 on the netbook HP 425
From page 47 of the user manual for the HP 425, "Press fn+f4 to switch the image between the display devices connected to the computer."
Press and hold the "fn" key on the keyboard of the laptop while pressing the F4 key to toggle the image between the laptop screen and the external monitor.
Thanks for using FixYa
Apr 23, 2011 | HEWLETT-PACKARD HP 425 WZ266UT Notebook
How do I get the HDMI connection on my HP Pavilion dv9000 to work. I have a HDMI connection on my Pioneer HD TV but I don't know how to get the connection on my computer to work. It there some trick I...
Normally the computer will detect that you have hooked in the HDMI cable and will automatically send an signal to the HDMI cable. It sounds like the "automagic" didn't work.
What you need to do is press fn+f4 to cycle the display mode to send a signal through the HDMI port. This works in a multi-mode way. You hold down fn and press f4 one time. Don't let go of fn and you should see a mode indicator on the laptop display. Each time you press f4 it will cycle to another mode. Depending on your specific configuration you might need to cycle through VGA first to get to HDMI.
Jan 09, 2010 | HP Pavilion dv9000z Notebook
Puzzled about simultaneous laptop+TV screen viewing way to setup
you still havnt given any extra info.
your pc has s-video your tv has s-video..
you link it up to view pc data on tv via fn +f4....(or whichever f key with square icon on it)
as soon as you link up nothing is seen on tv press fn key and f4 key together and you can see image on tv and pc press again image only on tv press again image only on pc again....
to watch continuous go to control panel click display,select screen saver and click powe and disable or reconfig sleep mode,hibernate.
eg..turn of monitor=never...turn off disks=never...system standby=never....change minute countdown in screensaver.
eg wait =5min change field to 2000min...
to view screen size on tv you use tv config 4.3,16.9,cinema,widescreen etc...
Jan 28, 2009 | HP Pavilion dv4000 Notebook
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Rely pc to tv
get yourself a s-video lead ...plug one end in pc and other in tv ( usually terminal with input/output rca jacks) audio / video jacks)
yellow white and red.
on pc press fn and f4 together (Usually f4 , look on the f keys and its the one with a square on it (usually blue colour)
assuming its f4 .....press fn and f4 together for laptop and tv monitor press fn/f4 again for tv mon only ....press fn/f4 again to return to pc only
Jun 25, 2008 | Compaq Pavilion ZT3280US Notebook
HP Pavilion dv9005us Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
