Question about HP Pavilion dv6000z Notebook
Hii, My computer is not booting up, no beeps at all even cant go to bios
  • singh268 Dec 26, 2008
    thanks sytem fan is running so i guess its not a power issue
    anything else which u can suggest
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Sounds like a power issue. If a computer tech came to fix it the first thing they would do is check to ensure all of your connections are plugged in, adapter is working, socket it giving you juice. So check for anything that has to do with supplying power to our PC. Including moving it to a different location and plugging it in.
  • 741 Answers
Have you tried putting in either your Windows CD or System Repair disc and seeing if it will boot up from there? We'll get it fixed just have to first try all of the obvious things frist.
Posted on Dec 26, 2008
  • 218 Answers
You might have one of the DV6000 computers with a motherboard failure as described on the web page below. Rather than try to diagnose your problem here, let me just suggest that you read the page and call HP if it fits your situation. HP is replacing these motherboards free even for units more than a year old, so it's worth a look. Goof luck!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277#c01087277_identify
Cooler is beeping cant stop it
Beeping codes are "type of device" and usually brand specific. Best practice is to identify the device, the brand, the model, and sometimes even the year. In regards to computers, beep codes are generally linked to the BIOS of a computer and/or to a brand. There are Award Bios beep codes, Intel beep codes, Dell beep codes, etc.. So, you have to gather a bit of information.
https://www.computerhope.com/beep.htm
https://www.intel.com/content/www/us/en/support/boards-and-kits/000005473.html
https://www.itechtics.com/check-hardware-details-windows/
I assume that cooler in this instance refers to a device to cool a CPU.
But some water coolers actually beep when they spring a leak! Don't even ask about wine coolers...
Sep 12, 2017 | Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Bios battery voltage is 2.4 volts, too low?
Hi there
It is a BIOS issue; try reflashing your BIOS since you dont have even a beep there is no any check on the system, even with a bad cpu, video or memory cards you should get a beep, so, reflash
Aug 26, 2012 | Computers & Internet
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
I kep getting an error on bootup about A: configuration in bios I can not boot the machine due to this problem. Also, I need to boot from UB drive, FINALLY got into bios, but it is still giving me the...
Is there a floppy disk in the A: drive? That "port" is usually reserved for a floppy disk, either 3.5 or 5.25in. You probably need to disable the floppy drive in the BIOS.
Jan 24, 2018 | AOpen Computers & Internet
I HAVE AN HP PAVILLION M8200N PC. i HAVE BEEN GETTING THE BLUE SCREEN OF DEATH. THROUGH RESTORE I WAS ABLE TO GET IT GOING. YESTERDAY IT WENT DOWN AND I WAS NOT EVEN ABLE TO GET INTO BIOS, I REPLACED THE...
It could be the hardrive might of had died.
If the bios boots then it stalls when its loading, its the harddrive. but when theres no beep, what you can do is also check is the computer memory take them out... and then insert them back in, or exchange them in different slots to see if you can get the computer going ,.. let me know if this work.
Feb 20, 2010 | HP PAVILION M8200N PC Desktop
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Hi-low beeps at boot. System won't even get to BIOS.
That is probably your ram. If you have more then 1 stick remove them and install one at a time in slot 1. If that isn't it you need to count the beep and duration of the beeps. I can then look up the codes. I will also need to know your bios manufacture.
Jul 09, 2009 | Biostar M7VIT Motherboard
Computer won't boot up
Have you tried a higher rated ATX power supply? Preferably a 350w.
Apr 22, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
HP Pavilion dv6000z Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
