Question about GE Nautilus 24" Built-in Dishwasher
Water will not drain
Water is coming out the front
  • 334 Answers
First, check for blockages.
Check the bottom of the washer for any broken glass, paper, plastic etc that can be blocking the drain.
Then check the hose and where it dumps into the homes main drain system.(Typically found under the sink attached to the garbage disposal or drain off the sink basin)
If the garbage disposal is bad or clogged, it can cause the DW to not drain as well.
If you have no blockages, then you likely have a bad pump.
If that's the case, check to see if the unit is under warranty.
If not, it is not uncommon for the cost of replacing a pump to approach the cost of buying a new washer. Especially if the washer is quite old or a near base model.
The parts alone typically cost 60 to 120 bucks. If you have to pay a tech to perform the labor, expect to pay between 175 to 275.
It is much easier to replace a DW than it is to replace the pump. So if you are unfortunate enough to have a bad pump, my advice would be to buy a new washer, and install it yourself.
I will be happy to help you with that as well.
(It's basically two hoses and three wires.)
Please don't forget to rate this solution.
Posted on Dec 26, 2008
How do I access the water pump to change it
Under the drum (front door) is usually a panel that comes off. IT is the whole bottom of the front of the machine. Then you can see the drain and the pump. The drain should have a large cap on it that you can remove. There is most likely a piece of clothing or something in the drain. Get ready for water to come out when you take the cap off the drain.
Aug 19, 2013 | Whirlpool LHW0050PQ Front Load Washer
Frontloadernot draining
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a hose there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
Pl click so if helped
Apr 08, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have sasui mobile type ari condition uni. there is a problem with water coming out from back side. water not going though drain line. cooling dosent have problem.
Check the elevation of your a/c unit. The elevation at the back should be lower than the front. Test by pouring water from the cooling coil and check if the water you pour goes to the condensate drain line. If water does not comes out, check if it has a small drain pump and a float switch to activate the drain pump. The float switch that does not actuate if water level rises may be the reason why water does not comes out of the drain line.
Sep 09, 2011 | Heating & Cooling
Water is not draining
remove the drain motor knob in back or front side of the machine..there may be a some dust clean it it will work
Jun 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader washer -water comes and just goes
Your problem is water siphoning because of the drain pipe too low or no air gap where the drain enters the wall. The drain hose from the washer should be at least 33 inches high.
Apr 06, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
93 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
