Question about Crosley CR248 Turntable
Needle slides across the record on Crosley 5 in 1 player
Just received Crosley 5 in 1 player. the arn slides across the record and the volume is real low evn though it is turned all the way up
    Problem Solver:
  • 17 Answers
You have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Record continously skips after 4 or 5 seconds.
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
May 12, 2013 | Crosley Cr6001a Turntable
Crosley CR-49TW volume
The wires that connect to the rear of the cartridge are easy to dislodge while changing a stylus. A flashlight will help you see underneath. There are tiny little push-on connectors that attach the wires to the pins.
Sep 20, 2012 | Crosley Audio Players & Recorders
Hi there, i have just bought a record player on ebay which looked very genuine but the needle seems to slide across every record that i have tried, would it be that the needle is blunt or is there a...
Chances are it was sold with a faulty stylus. The only other thing to try is to increase the weight at the end of the tone arm. It might have numbers on, turn it up in stages to see if that solves it
Jan 20, 2011 | Crosley CR249TA Turntable
I have a crosley radio, and when I use the turntable, the needle slides across the record,how do I get this to stop?
Check the needle, it may be worn out. The needle point that sits on the record track should be very sharp.
Oct 23, 2010 | Audio Players & Recorders
My record stylus slides across records
There are a couple of reasons this is happening. First and formost gently lift the stylus arm and blow any and all dust off of the needle.You may even have to gently 'pinch' off any accumulated dust. Be careful since you don't want to pull the playing needle off.
This is a very common problem. If this does not help, you need a new stylus needle for the arm.
Dec 04, 2009 | Technics SC-DV290 System
BSR turntable arm slides across record
There can be a number of reasons for this.
Have you checked that the stylus tip has not broken off? this is a common cause and will require a new stylus.
Jan 17, 2009 | Crosley CR248 Turntable
Crosley CR248 Turntable Logo
1,934 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
