Question about Frigidaire FGFB75D Gas Kitchen Range
Oven wont ignight
Over ride the oven ignighters
  • 57 Answers
Replace lower igniter.
Posted on Sep 22, 2009
My oven won't light.
Does it glow real bright like orange or just red. Because if it's not real bright orange, the ignighter could be bad. The oven will not light if the ignighter is not hot enough.
Sep 22, 2014 | DCS RGT-366-L
Maytag range ignighters don't work
Make sure the cord is securely plugged in and there is power to the outlet. murf427
Aug 01, 2012 | Maytag Kitchen Ranges
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
The top burners do not light?
your ignighters are not working,,,you need to have it serviced for them to work again..the ignighters are what start the heat process.
Jan 08, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven repair
just because it glowes dont mean its up to par try changing the ignighter it can be weak
Oct 27, 2008 | Ovens
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FGFB75D Gas Kitchen Range Logo
164 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
