Question about Kenmore 24032\24036 Top Load Washer
LG WD-8013F Washing Machine Water Sensor
Our washing machine is showing a water level sensor malfunction. Can you please tell us where this sensor is situated on the machine? We would like to try and fix/replace this ourselves if possible.
  • 916 Answers
It is located at the end of a rubber tube coming from the bottom of the drum.
there may be blockage in the level sensing tube, a rubber hose from the bottom of the drum to the water level pressure sensor. disconnected the hose at the pressure sensor, gave a big blow into it by mouth to dislodge the foreign material, (blow until you hear bubbles in the water) . After clearing the tube, you need to pump out any water in the drum and then reconnect the hose to the pressure sensor.
Posted on Dec 26, 2008
  • 700 Answers
The sensor is in the control cabinet and how you can spot it it will have clear plastic tubing going to it. good luck
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
Mar 13, 2018 | Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
Remove the wall plug which _should_ reset the main board. If that doesn't work, you have to manually drain it by unclipping the drain hose and lowering it into a bucket.
Error 12 (E12)
Washing machine has detected an overfill situation This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
  • Check for overfoaming or over soaping
  • Check the air chamber and the pressure switch hose
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3848-logik-washing-machine-error-codes
Jan 20, 2016 | Washing Machines
Model WD-8013F. Why does it continue filling after wash cycle should start?
water level sensor may be faulty, or the air tube that works in conjuction with the sensor may be plugged. check out repairclinic.com or appliancepartspros.com for videos on this issue and fixes.
Jul 17, 2015 | LG Washing Machines
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Apr 06, 2015 | Samsung Washing Machines
    What eroor8 in weat point washing machine
    Error 8 Washing machine has detected an
    washing machine. Also check the pressure sensor and
    overfilled with water. Check for overfoaming or over
    soaping Check the air chamber and the
    pressure switch hose Check water level sensor Check wiring to water pressure
    sensor Check connections to water level
    sensor Check main electronic controller
    Jul 14, 2013 | Washing Machines
    Kenmore washers spins b-4 draining spilling water out the top
    Possible that the water level setting is kept too high or that the water level sensor, the pressure switch is malfunctioning.
    You need to identify and confirm the working of the pressure switch to establish the fault.
    Jan 12, 2013 | Washing Machines
    How do you fix fe error
    LE means washing machine electronic controller has detected an overfill situation
    * check for over foaming or over soaping
    *check the air chamber and pressure switch hose for blockage
    *check water level sensor
    *check wiring to water pressure sensor
    *check connections to water level sensor
    *check main electronic controller
    Nov 07, 2012 | LG Washing Machines
    Kenmore 24032\24036 Top Load Washer Logo
    122 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
