Question about Sony Handycam CCD-TRV37 Camcorder
Camcorder dead whilst videoing camcorder just died !!! tried putting on mains charger and orange light that would normally come on whilst unit charging nothing there !!! also when switched to record green light that would normally come on not there unit totally dead!!! and cannot retrieve disc that is in handycam???????
  • 30 Answers
Hi There, You probably have a blown fuse or 2. Either your battery or impact damage may have caused this. Unit needs to be serviced at a shop.
Thanks, mr cicmo
Posted on Dec 26, 2008
When I connect the battery charger to the camcorder it doesnt even even show that I have the battery charger hooked up nor does it charge the camera. Could that be a problem with the camera or the charger?
I got hold of Canon support. I had the same problem. Got a new battery, fully charged and would not run the unit. Canon told me to do a system reset. pull out main battery and aux battery (bottom of unit) and to power switch to aux for 90 seconds. the put batteries back and it should work. Hope this helps.
Nov 05, 2010 | Canon ES50 8mm Camcorder
Camcorder not charging
Since the camcorder will power up and work with the charger connected, it sounds like the battery has died and will no longer hold a charge.
Feb 06, 2010 | JVC GR-D850 Mini DV Camcorder
My Canon FS100 is dead, it does not light up with power adapter, the battery is dead too.
The Charger that comes with the cam is said to go faulty 99% of the times. I too was shocked to see my cam in the dead condition. Checked a few things on the multimeter and found the charger to be faulty, tried replacing the charger with power supply that i designed for 8.4Volts output and the cam was back to life and started charging.!!! Hope this should help. ... you can email me for the desing of the charger or buy a new charger from an auhorised Canon dealer.Email : ankurpuranik@gmail.com
thanks 7 regadrs,
Ankur Puranik
Dec 21, 2009 | Canon FS100 Flash Media Camcorder
Charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Mar 10, 2009 | Nintendo DS Console
No batteries work
turn flash to off in menu and it will at least work.
Dec 29, 2008 | Aiptek ISDV2.4 Flash Media Camcorder
Brand new psp battery will not charge
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Disk finalization error
dont know if youve found a solution already, but:
you cant finalzie the disc using battery power, you need to use the ac adaptor. This is something you should have got with the camcorder. its basically the charger plus another cable. so, plug in the charger to the mains as normal. then remove the battery from the camcorder, you'll notice a round hole in the camorder, this is where you plug in the cable i mentioned earlier, the other end of the cable goes into the same size hole found on the battery charger. that's it - you now have power to the camcorder from the mains. switch on the camcorder as normal and finalize the disk.
Jan 13, 2008 | Panasonic VDR-D100 DVD Camcorder
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony Handycam CCD-TRV37 Camcorder Logo
179 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
