Question about GE Profile JTP56 Electric Double Oven
Installing my oven
I'm confused, i have a older house, when i pulled mu older oven out it had only 3 wires to hook up, white black and copper bare.
Now my ge double jtp27boa2bb has a red wire added to it. How do i hook this up?
  • aa7672002 Dec 26, 2008
    Sadly i dont have the old oven to check the plate, but my brother inlaw check volts coming out and hegot 110 out of both.
  • 700 Answers
You may not be able to dur this because the whit shoul be a neutral and the red and blk 22o and the copper is your grd. look at the old oven's data plate and see if it says 120/220 volts ok? you may have to get another wire to the ovens
Posted on Dec 26, 2008
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
I am hooking up a double oven to my house the wires coming from my house is black black and copper both blacks are hot the wires coming from the double oven is black red white and copper How do I hoo
The blacks are hots which wilkl give you 220 volts the bare one is the neutral conductor so the hook up the stove black to one lead red to the other white to bare.
Nov 06, 2012 | Ovens
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
It has a white wire,red wire,and bare wire but I on have 2 black wires and one bare wire for ground that comes out the wall.I don't know what hooks up with what
Hi and welcome to FixYa, I am Kelly.
What is the model number so I can look up the installation procedures for THIS oven?
Usually for a 3 wire connection it will be connected as follows:
1 WALL black to the left terminal block terminal
The bare copper wire to the center terminal of the terminal block
2nd WALL black to the right terminal of the terminal block
See this picture link:
http://www.ask-the-electrician.com/images/RANGE%203-WIRE_CORD_CONNECTION_250.JPG
If you notice in the picture it shows a black red and white connection.
Red = black for your connetion 115VAC
White = bare wire neutral Ground
Black = 2nd black for your connection 115 VAC
When the power is connected properly and using the house wires as a reference if you are
reading it with a meter you would read EITHER black wire to the bare wire = 115 - 120VAC
Reading Black to Black = 230 - 240 VAC
If you still have questions feel free to respond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Dec 02, 2010 | Ovens
WHERE DOES WHITE WIRE ON WALL OVEN GO FOR HOOK UP - WE HAVE RED, BLACK, WHITE & COPPER
white wire goes in the middle copper goes to ground or chassis
Oct 04, 2010 | Whirlpool Ovens
Oven says: ''supply open neutral'' no buttons work what to do?
That means the range is not connected properly, or the power supply to it is not correct. The range needs the neutral (along with one of the hot leads) to supply the 120 volt portion of the voltage required to operate the control. On built in ovens, the red and black are connected to the two hot supply wires, the white to neutral, and the green or bare copper wire to ground. If your supply only has three incomming wires (older homes) then the green (or bare copper wire) and white are both connected to the neutral.
Nov 11, 2009 | GE Profile JT980 Electric Double Oven
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Moffat oven
U need to open/unscrew back and look at bottom connections to the left ( looking from the back) Earth green and yellow- Blue is neutral and Brown is live you probably need electrical female spade connectors for your end of the 'hard' wire !!
Jun 07, 2008 | Jenn-Air JJW8330D Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
103 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
