Question about Air Hogs Toys
Air Hogs Micro Havoc Heli spins wildly
One moment it was working fine, now it spins wildly. It looks fine. Any ideas?
The same thing happened to me. It turned out that some hair and fibers got wrapped around the tail rotor axis. I pulled the tail roter off and cleaned it out. After I put it back together it worked fine. I hope this helps.
Posted on Dec 30, 2008
    Problem Solver:
  • 8 Answers
The tail rotor on a helicopter is what controls the spin.
Posted on Dec 26, 2008
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
My airhogs heli does not fly but just falls to one side after a few spins
Right here is the support site.
This is the place to get help for Air Hogs.
They also have a "community" link which may do you some good too.
May 24, 2010 | Air Hogs Havoc Heli Helicopters
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Air hog havoc goes up and down just fine, no steering control
The steering control only makes the copter rotate.
But if the heli is properly balanced a right turn should get you some forward motion. A left turn should just make it spin back to the left.
Adding weight to the front of the copter will give it continuous forward motion. Then you will lose the ability to hover.
If you visit the Air Hogs website (, select "need help" and then Havoc Heli, then crash course, the video will show you how it works.
I also find that climbing makes the heli spin left and descending makes it spin right. So full right for initial startup, then a little right when climbing, and a little left when descending helps to smooth things out.
Keep in mind that this is a very small and cheap helicopter. It took me a while to get used to flying in circles to the right but with practice I have been able to get it to go somewhat where I want it to. I can take off and land from the coffee table without crashing.
Jan 15, 2010 | Air Hogs Havoc Heli Helicopters
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Havoc heli flight problems
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Jan 05, 2009 | Air Hogs Havoc Heli Helicopters
Havoc heli frequency
You only need one frequency to be able to fly it. So it's working fine.
Dec 27, 2008 | Air Hogs Havoc Heli Helicopters
Toys Logo
785 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
