Question about Neff H7871A2GB 800 Watts Convection / Microwave Oven
Removing the microwave door
We have the British version of the above Neff oven. We had an accident with some hot gravy which entered the cavity between the two glass panels which make up the oven door. I asked Neff UK how to split the door so that I could clean up the glass inside. They said to book a service call. I need to remove the door from the oven casing so that I can dismantle it and clean it. The door appears to be screwed together with torx bolts. Question (a) Is it safe to split the door? (b) Is it easy to separate the door sections once the door is off? I can get the oven out of its cabinet and have already renewed the oven light. Any advice would be welcomed. Thanks.
  • Anonymous Mar 18, 2014
    rubber seal came off glass door on neff oven B46E74NOGB slide way door
  • Anonymous Mar 22, 2014
    Can the door of a Bosch Gourmet HFT879 Microwave/ Combi oven be removed for cleaning and if so how do you remove it?
  • Neff Master
  • 9,098 Answers
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Posted on Apr 17, 2007
    New Friend:
Removing door assembly and replacing related parts of Neff B7740N0GB
It is helpful to have access to the spare parts diagram from the Neff website to visualise this procedure.
To work on the door it is best to remove it from the oven. With door partly open lift the whole door upward. The hinges slot freely into the body of the oven but are on very strong springs and it can take some effort to lift them clear of the body of the oven. Take care not to break the black plastic locking hooks.
Place the door on a flat surface front down, resting on the handle. The raised plastic back is clipped into place. Use a thin flexible tool to wriggle between the plastic back and main body of door, start on sides and bottom and gradually unclip. Once the sides and back are clear the top should come away easily. Note the part by the hinges is very thin and fragile.
Lifting away this back piece will reveal six small screws holding the microwave screen assembly to the front door panel. There are two larger screws that link through to the handle. Undo them all. The microwave screen assembly (which includes the hinges) is now attached to the front door panel with a series of fragile plastic clips hooking over the assembly. Gently ease these clips away, once the bottom clips are released the assembly should come away easily.
The microwave screen and glass door panels can now be cleaned, be gentle cleaning the microwave screen and ensure all is dry and smear free before reassembly.
The black plastic locking hooks can be replaced, these are attached to the microwave screen assembly with a spring and two hooks that slot into holes in the side of the microwave screen assembly.
To reassemble, reverse the procedure, ensuring that the panels are snapped back into place and screwed in securely.
To replace the reassembled door into the oven. The hinges need to be pulled back and held in that position but there will be a lot of resistance from the springs. Get a couple of medium size allen keys. Pull each hinge back to reveal a small gap between the hinge and the door assembly. Drop the shorter end of the allen keys into this gap, these should hold the hinge open while you fit it back into the main oven. Once the hinges are in the oven, with the door open still, retrieve the allen keys. If the door does not seem to want to shut the hinges are not fully located, try lifting the door and jiggling it to encourage the hinges to fully locate.
Posted on Nov 18, 2014
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Dec 08, 2012 | Neff Microwave Ovens
Sparking inside microwave door
There is exposed metal, when magnetron is running it will arc if there is exposed metal in the interior cavity which is more common, I have not seen this inside microwave door, inspect door carefully when you open it to see if there are bare spots. The manufacture use to sell microwave cavity paint to prevent this very problem, if this is not corrected it will short out the magnetron.
Jun 09, 2012 | Neff B7740N0GB Microwave Oven
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
Panasonic 1200 watt microwave shuts down in 10-15 seconds
Check the door switches to make sure they are not faulty, otherwise it may be the inverter.
IS the microwave in a cavity? If so, you need to have at least 15cm (6in) space above the microwave, 10cm (4in) behind the microwave, and 5cm (2in) on either side, as the latest Inverter microwaves run very hot and need a lot of ventilation.
May 26, 2010 | Panasonic Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Replace front glass door of a Neff microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 19, 2008 | Neff H5430 Convection Microwave Oven
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Neff B7740N0GB Microwave Oven
NEFF 7871 electrical problems
neff built in microwave cannot open the door
Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Jan 15, 2008 | Neff B7740N0GB Microwave Oven
NEFF H5632NOGB/01
Open door, place hands in centre of roof, lift gently and move back. This reveals four screws that mount the frame to the outside wooden housing, remove these and then remove the frame. Now lift the microwave out of the oven housing.
Dec 14, 2007 | Neff H5642 Convection / Microwave Oven
Neff H7871A2GB 800 Watts Convection / Microwave Oven Logo
1,525 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
