Question about Palm Tungsten E Handheld
Blank Screen My screen for the tungsten has been slowing dimming for the last 2 weeks and now I can't see anything clearly, the device still works and it isn't fuzzy or diced up in the display it is very dim. I have tried to reset with no results. The first week I had this problem I could tap the device and it would return to being clear. Please advise. Do I need to replace the battery? Or has the device simply died?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
In system you have a selection of background brightness.
Posted on Dec 30, 2008
System won't boot up blue screen
Sounds like your hard drive shot craps. No other messages, beep codes, or opportunities to hit a key to get into BIOS or something? Machine making any grinding noises that it wasn't before?
Dec 11, 2013 | Dell Inspiron One 2020 All-in-One Desktop
I have a HTC 6800 that started acting funny about a week ago. At first the screen got lines across it when I would open the keyboard, then after a couple of days the srceen just froze when the keyboard was...
I had this same problem, there is a thin line of wires connecting the bottom half and top half of the sliders, after awhile it just plain wears out and will generally crack, without these wire anything on the front of your phone will no longer work. The screen is black but stil lights up a little bit and occasionally the buttons light up but its pretty much toast I'm sorry to say. I upgraded to a HTC Touch Pro 2 and am happier than ever!
Jan 18, 2010 | HTC PPC-6800 Smartphone
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
My battery only last 7 hours instead of 8 hours I have only had it a week
Battery drainage can be caused by many ways. Although if the manufacturer states that it can play 'up to' eight hours, then it's possible with heavy usage, bright screens and powering on & off the device may possibly shorten the battery life.
If your mp3 player has the option, you can always dim the screen brightness, let it go into blank screen after few seconds, and do little to conserve the battery. It's not too bad considering you're only one an hour short. I'd be concerned if you were getting less than half of what the manufacturer states.
Nov 07, 2009 | Coby MP-610 MP3 Player
Blank white screen
Now reinstall the OS of the device connecting with desktop manager,before reinstalling take a backup and after the installation do the hard reboot.
Aug 05, 2009 | RIM BlackBerry Bold 9000 Smartphone
Water spilled on palmone
May still be good. Let it dry out for at least a week in a low humidity place but not so that it gets hot. After a week plug it into your charger and hit the reset button and see what happens. It may need a little longer to dry out if it doesn't boot up.
Mar 27, 2009 | Palm Tungsten E2 Handheld
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
USB device not recognized or has malfunctioned on hotsync
Last week, windoze started barking the same complaint at me. A hard reset (of my Tungsten E) solved the problem. Caution: A hard reset (keep the power button pressed while performing a normal reset. Only release power button, when Palm logo screen appears. The press up-key) delete ALL data (even the identity, i.e. hotsync ID) from your palm - so be sure to have a recent backup!
Nov 23, 2006 | Palm Tungsten E Handheld
Palm Tungsten E Handheld Logo
191 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
