I do not know my password or code to get my Wii to hook up to the wireless router. I see it but dont my security code. How do I find it?
Because it is not your rouder on internet and that persons is different
Posted on Dec 26, 2008
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
Error code 51331 when trying to hook up Netflix through the Wii and a wireless router. Checked the key code on router, what setting do I need to change
How to fix: Make sure the password or key is entered into the Wii exactly as it appears in your router's settings. Keep in mind that security keys are case sensitive. A simple typo may be causing the problem.
Don't know how to find your router's password or key?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
If you're not able to locate the password here, select the brand of your router below and we'll show you how to access your router's settings.
for more help visit CBR Tech Solutions
Jul 21, 2014 | Video Game Consoles & Games
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
I NEED THE Home Wireless AR SECURITY CODE TO HAVE INTERNET IN MY WII
You will need to login to your wireless router to get the wireless password. You will need to know the username and password to the router in order to access this information. You will need to talk to the person who setup the router for the information. The router website will vary depending on the brand of the router. If you do not know the router username and password. You will want to contact the router manufacture for assistance acquiring that information.
May 31, 2011 | Nintendo Wii Console
I have a wii, and it is asking mefoe a security key or password. how do i find it
If you only have that modem, and no wireless router, the Wii isn't going to hook into your internet.
If you do have a router, the password is the one you need to hook up wireless with a computer or laptop, and would have been set up by you.
Mar 15, 2011 | Arris SURFboard® SB5101 Cable Modem
I bought a wireless router and when I try to hook it up to the wii I do the test and it says error code 50300
Error code 50300 for the Wii signifies that your wireless settings are not correct. What you have to do is go into the Wii Internet setup, and make sure that the settings on your Wii are identical to the setup in the wireless router that you are trying to use. The most common problems include:
1) SSID, which is the name of the wireless network that you setup in the router.
2) The WEP or WPA key, which is the security password that you setup for either of the security protocols that the wireless networks use. You should definitely use the WPA security protocol as the WEP protocol was hacked some time ago.
3) Any manual settings you may have setup, such as whether you are using a fixed TCIP address or a dynamic one.
If you setup the router yourself then you should be able to check the settings on the Wii on your own to verify they are correct. If you had someone else setup the router, use the following link on the Nintendo website which will help you go through the Wii settings to ensure all is well:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=50300&system=Wii&locale=en_US
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 22, 2011 | Nintendo Wii Console
I am tryin to hook the enternet up to my wii
Let's get you connected!
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 26, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
Jan 23, 2011 | Nintendo Wii Console
What is my security key so i can hook up my wii system to the internet
TO GET THE WIRELESS PASSWORD
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Default password is admin
Step 4 : Click wireless
Step 5 : Choose wireless security
Step 6 : Here you can find the Password
Step 7 : Try to connect with this password
let me know if this works
Regards
TOM
Dec 27, 2010 | Linksys Wireless-G Broadband Router
Internet connection
Your Wii will only connect properly to your wireless router by the setting WEP any others and you get problems. Set your router to WEP and encription strenth to 64bit, enter a WEP key "or passphrase to generate a WEP key" its a 10 digit password for your wireless security. Oh also nintendo will only work on chanel mode G&B not G not B but G&B.
Hope this helps.
Thanks
Matt
Jan 04, 2008 | Nintendo Wii Console
Computers & Internet Logo
Alun Cox
David Payne
David Payne
