We have a whirlpool hotwater heater model #fg1404t3nv and we can not get the pilot light to stay lit. help please we need hot water and do not have the money to replace it
  • 334 Answers
Fear not, unless you havewater leaking from the tank you won't have to worry with replacing it.
Heres how your heaters ignition system works.
The Pilot is lit, and the flame sensor detects flame and sends signal to the gas valve.The gas valve then sends gas to the burners and the burnes ignite.
If the gas valve does not recieve signal from the sensor it will not come on and it will shut off all gas to the pilot, and burners to prevent raw gas from dumping into your home.
If your system has a thermocouple, 99% change the problem is the thermocouple.
When I service a customers unit, I automatically replace the thermocouple because they are so notoirus for going bad.
You can buy one at Lowes for less than 10 bucks.
To locate the thermocouple, go to the gas valve, fint the small copper tube (about as thick as a pencil lead) and follow it to the pilot. The sensor will be slightly larger in diameter and about 2 to 3 inches long.
You can try cleaning the sensor with steel wool, but usully they just need to be replaced.
To replace it, turn off the gas, unscrew the nut holding the tube in the gas valve, and disconnect the sensor from the ignitor/pilot assembly. Make sure your new T-couple is long enough, as the come in different lengths, you can simply coil the extra length up out of the way near the gas valve.
Install the new one as you removed the old one.
Relight pilot, be sure to hold the button down long enough, and enjoy your hot shower!
If you have any other problems, let me know, and I will be glad to help you.
Please don't forget to rate this solution.
Posted on Dec 26, 2008
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 24, 2011 | Noritz Water Heaters
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Whirlpool hot water heater serial#0426117756 also know as american hot water heater The pilot light won't stay lit. Please help. I have been without hotwater for two days.
sounds like you need to replace the thermal coupling. This component sends a signal to the gas valve that there is a pilot
Jul 30, 2009 | Water Heaters
Pilot light going out on whirlpool hotwater heater-Fgif403t Flam
Paint fumes can foul a thermocouple. If you have painted anywhere in the home this could be the issue otherwise its the gas valve.
Phil
Dec 08, 2008 | Water Heaters
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
