Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Why does my KAC-8404 cut off at high volume bass?
Ive got 2 Kenwood KFC-HQ718 speakers and a Pioneer TS-WX301 sub hooked to a Kenwood KAC-8404 amp... the system was working fine up until a week ago...the problem is when i raise the volume above half, it works fine... but as soon as heavy bass kicks in, the amp cuts off for a few seconds then comes back on... n it keeps doing this if the heavy bass continues...wht cud b the problem and how can it b fixed?
  • 3 Answers
My uncl had the same problem and he went back to the audio shop twice...Then called me...I discovered that the powr cords they used were not thick enough,giving the amp a low current to work on...but if you have the original cords you got when you bought the amp...it might also be a weak power supply....try playing the music while driving on a high speed or while reving the car to give more voltage from the alternator...If that doesnt work...come and shoot me please...im out,PEACE
Posted on Dec 29, 2008
  • 21 Answers
Amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Posted on Dec 26, 2008
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
How to wire kenwood subwoofer to kenwood KAC-8404 car amplifier
Hi, this is a 4 channel amp. Not really designed for a sub, but you can use it that way. Cay you tell me all the speakers you want to hook up--need their sizes or frequency ranges and their impedances. Or, if you have model number for the sub that will do. Is it one sub or 2? I will then get back to you with a recommended setup. OK?
Jan 18, 2011 | Kenwood Car Audio & Video
I have a Kenwood KAC-9105D amp with 2 Kenwood KFC-W3012 subs in a seal box. When i turn the volume up loud the bass fades out for a few secs and then comes back to being loud again, this keeps happing over...
Cant solve the problem but can help calling kenwood in am i have to of those amps and both do same thing its a cooling problem only 1 little fan pulling air out going to buy couple bigger fans and install in both ports and will let u know how it works out
Aug 06, 2010 | Kenwood KAC9105D Car Amp
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Can i kook up 4ohm dvc sub to a kac-x810d amp?
No, the sub is dual 4ohms...meaning if you parallel the positive speaker terminals and the negative speaker terminals you will have a 2ohm sub. Conversely, if you series the pos and neg you will have an 8ohm sub. if you wirte to just one set of terminals on the sub you will have a 4ohm sub.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Apr 12, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Speaker type
I posted a comment on your other post not nodicing this one. But commenting on the choice of amps, It would all depend on what the model number is on the pioneer amp. Also it would depend on what kind of sound you want. Could you get me the model number of that and double check your model numbers for the kenwood sub and amp. The amp that I show when I googled it was rated at 250 watt at 2 ohms no where near 1000. so if I have the wrong amp let me know, I would like to help. Thanks
-Andrew Hawkins
Jun 01, 2008 | Car Audio & Video
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Witch is better
hi there. ill start with the wiring. you should have a blue remote lead going to the back of your head unit, the power cable running straight from the amp to the battry, the earth should be earthed in a fairly decent place, any metal inside the car realy, and then your wires pos and neg from the amp to the subs. the reason why the kenwood might not have much base on it is to my knowledge, there should be a switch somewhere on the amp that will increase or decrease the power input for the speakers, if this is set very low then hense why theres not much base comming from them. if the amp is on and its giving something to the subs it probably isnt the wiring. try checking the amp for the switch first, if you cant find it try the pioneer amp and see if theres any diference.
dont hesitate to contact me if you get stuck
cheers, adam
Oct 31, 2007 | Pioneer GM-7200M Car Audio Amplifier
Kenwood audio equipment
If it was mine i'd want $200-$300 if in mint condition. Try a classified in the local paper or online ads.
Sep 11, 2007 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
489 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
