Question about Motorola Mobility RAZR V3
What is going on with my phone?
I have the alius. For no reason it started vibrating uncontrollably and the only way to make it stop was if i take the battery out, and when i put the battery back in it keeps vibrating and the camera light flashes on and off + the screen goes white. what happened? what should i do?
    Brigadier General:
  • 7,752 Answers
You can try reflashing the firmware on the phone but i think the mainboard needs replacing to correct this issue............
Posted on Dec 26, 2008
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
In the spin cycle it makes a loud banging noise and vibrates uncontrollably. when u raise the lid it stops spinning right away. is it worth it to fix this or replace it?
You may have to lift the lid and rebalance the wet clothes inside
make sure that the machine is level and the bowl supports or in good condition as an off level bowl will go to unbalance on start of spin
Apr 13, 2015 | Washing Machines
I have a Samsung Intensity 1 and it stopped vibrating. When I have it set to vibrate and try to test it, it says it should be vibrating and it's doing nothing. It makes regular sound, but for some reason...
There is a small motor inside the phone that makes it vibrate. That motor could have gone bad. You should be able to either get it repaired or replaced by your carrier.
Nov 06, 2010 | Samsung SCH-U450 Cell Phone
Vibrations
go to settings on xbox or options it should say something like fix the vibration or something like that
May 23, 2010 | Microsoft Xbox 360 Controller
My LG Env stopped vibrating on inbound texts
Make sure you go in settings and somewhere either under Profiles or Settings you should be able to make it vibrate. Or if there is a volume rocker on the side of the phone(usually two buttons with arrows, one pointing up and one pointing down) just use those and set it to vibrate. Hope I Helped!
Jan 28, 2009 | LG enV VX9900 Cellular Phone
Outgoing text vibration
Good Day,
Beginning with the start menu, go to settings, then sounds & notifications. From the drop down list, go to outgoing message and click the "play sound" box (to empty). That should stop the ringing and vibration.
Hope this helps
Jan 02, 2009 | Verizon Communications HTC XV6800 Cell...
Vibrating when someone leaves a voice msg
it is a known fault, contact LG customer service to see if there is a software upgrade.. it will involve you sending your phone off for a few days (7-10 days typical) but that should sort the problem
Jan 11, 2008 | LG Prada KE850 Cellular Phone
Rings when set to vibrate.
you may need to edit the 'settings' or 'details' for the vibrate profile. hope this helps :)
Oct 28, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Stop the Vibrating
Sounds like the phone may have gotten wet. Check behind the battery for a white circle sticker, it will be red if the phone has gotten wet. Best of Luck.
Sep 25, 2007 | Motorola Mobility i560 Cellular Phone
I have the sgh-a707 and it won't stop vibrating.
welll there is a way to stop your problem -if on the side of your phone there is an arrow going up and down you can adjust it that way and put it on your volume control also if u go into the sounds men you will most likely see application volume once you press that you will see 1. sound 2. vibrator if it is in the on mode go to off and that will take care of your problem
Aug 09, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Motorola Mobility RAZR V3 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
