Question about HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop
Pc beeps five times when swtched on
I have hp xw6200 trying to build new 2gb memory hard drive new 640gb 128 pci graphic card still nothing can you help. thanks lee
  • 40 Answers
PC beeps are usually memory-related problems. make sure you are using the right memory for your computer. the specs should be a DDR2 DIMM 240 pin PC2-3200. what specs do you have?
also do you have two 1G memory sticks or just one 2G memory stick? it may be that your computer doesn't accept a 2G memory stick but rather 1G memory sticks. good luck.
Posted on Dec 26, 2008
Will this graphics card work with my computer?
1) HP xw6200 Workstation desktop computer,
http://h18000.www1.hp.com/products/quickspecs/11975_div/11975_div.HTML
Power Supply: Maximum rated Wattage - 500 Watts.
XFX ATI Radeon HD5750 graphics card,
http://www.ebay.co.uk/itm/2GB-ATI-Radeon-HD-5750-1GB-HDMI-1080p-BluRay-EyeFinity-Gaming-Graphics-Card-/120973408169?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item1c2a93b7a9&_uhb=1#ht_4735wt_1080
Yes.
1) Install the software F-I-R-S-T, then physically install the graphics card.
Windows running, put the Installation disk that comes with the graphics card, into the CD/DVD drive.
Load all software. The drivers, and Catalyst Control Panel.
Windows will NOT use the software until the graphics card is installed, so don't worry about not having graphics in the meantime.
2) Computer unplugged from power FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, AND before removing any parts out of their anti-static bags, or cartons.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Physically install the graphics card.
(The Lock Lever on the PCI-Express x16 slot, goes UP to install a graphics card, or to remove a graphics card. It looks as though you should push down on it)
http://www.txcesssurplus.com/servlet/the-9225/HP-408544-dsh-001-xw6200-WorkStation/Detail
Looking at the black PCI-Express x16 slot, with it's green Lock Lever, it looks as though there should be room for the graphics card.
Looking to the right of the green Lock Lever, look at the 4 gold colored Choke Coils. It may be tight, but the graphics card should clear the first two.
Areas of concern, though;
1) Power Supply:
The XFX Radeon HD5750 graphics card, requires a minimum of a 400 Watt Power Supply.
The graphics card doesn't use 400 Watts, of course. This is the minimum power requirement by the graphics card manufacturer, and based on the power the card needs, and the rest of the computer.
XFX, just like all graphics card manufacturers, uses a computer system set up to the maximum, for a test unit.
Gamer style motherboard.
Powerful Processor, that is probably a dual core, or quad core.
Maximum amount of ram memory.
Two optical drives
Two or more computer case fans.
Two or more harddrives.
You get the picture.
Power consumption has to be based upon what each individual hardware component will use, AND the graphics card.
Power Supply:
Problem is, the computer has some age on it. From searching it seems to have been made in 2004. Makes it 8 years old now.
Makes that Power Supply 8 years old now too.
A) Pre-built computer manufacturers, such as HP, Gateway, Lenovo, Toshiba, etc., have their components made by someone else.
The Power Supply is one such component.
Usually a generic Power Supply manufacturer, such as Bestec, or HiPro, or Delta, for HP computers.
Low quality electronic components are used in these power supply's.
Isn't a big deal usually, until you start to tax the limit on the Power Supply, such as installing a powerful graphics card.
Power Supply manufacturers also had a great tendency, to overate their Power Supply's back in the day. Made the Power Supply sell better, 'fudging' the actual Wattage rating.
Wattage was actually more like 60 to 70 percent, of what was stated.
300 Watts (60 percent) to 350 Watts (70 percent) is more actual.
The XFX ATI Radeon HD5750 also requires a 6-pin PCI-Express power cable, coming from the Power Supply, and connected to it.
The maximum amount of Wattage a PCI-Express x16 slot can deliver, is 75 Watts.
The 6-pin PCI-Express power cable delivers an additional 75 Watts,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
"This cable is used to provide extra 12 volt power to PCI Express expansion cards.
PCI Express motherboard slots can provide a maximum of 75 watts.
Many video cards draw significantly more than 75 watts, so the 6 pin PCI Express power cable was created.
These high-power cards draw most of their power from the 12 volt rail so this cable provides only 12 volts."
(Yellow wires are 12 Volt wires. Red wires are 5 Volt wires, Orange wires are 3.3 Volts. All are DC voltage. Black wires are Ground wires)
Will your Power Supply have a 6-pin PCI-Express power cable?
I doubt it.
In the Playtool link, see the 6-pin PCI-Express adapter power cable, shown on the right?
Takes TWO 4-pin Peripheral power cables,
(Commonly misnomered as a 'Molex' power cable),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
If you are going to use one of these power adapter cables, you NEED TWO 4-pin Peripheral power cables!
HAS to have TWO Yellow 12 Volt wires going to it.
Will using a 6-pin PCI-Express adapter power cable, and One 4-pin Peripheral power cable work?
Most of the time yes.
PROBLEM is,
Over time the;
1) PCI-Express x16 slot contact pins -> BURN
2) Gold plated contact pins on the bottom of the graphics card -> BURNS
3) Connection on graphics card for the 6-pin PCI-Express power cable - BURNS
4) 6-pin PCI-Express power cable's connector -> BURNS
No if's, and's, or but's; it WILL happen.
Result is usually throw the motherboard away, and the graphics card.
So you may be looking at getting a better Power Supply.
Here is one example that will work,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899124&CatId=1483
A) 600 Watts. Gives you an additional 100 Watts of power. Less strain on the Power Supply.
B) 120mm fan. A larger fan turns slower, therefore makes less noise.
Puts out more air flow than an 80mm fan, even though it turns slower.
C) Has all the power cables required, plus more.
D) Has TWO 12 Volt power rails.
12 Volt 1 is capable of 23 Amp's.
12 Volt 2 is capable of 20 Amp's.
Total combined Amperage for the two 12 volt power rails is 43 Amp's.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01463539
http://h20464.www2.hp.com/media/278E215F-8E76-416C-BBE2-32F7B25FB1A1/xw62_FRU_video_powersupply.htm
Gamer computer?
Not IMHO. Uses ECC ram memory.
That is Error Correcting Control ram memory. The ram memory runs the data through it twice, in order to make sure everything is correct, before using the data.
This is the type of ram memory a Server computer uses.
Could be wrong, and it could be used as a gamer computer, though. We will see when you are done, IF this is the intent.
[ http://en.wikipedia.org/wiki/ECC_memory
Reasons for not using ECC:
"A performance decrease of around 2-3 percent, depending on application, due to the additional time needed for ECC memory controllers to perform error checking;"
Regards,
joecoolvette
Aug 31, 2012 | HP xw6200 PC Desktop
HP Workstation XW6200 starts to power up and then just stops - will not boot
First open cpu cabinet.
Then Refix your RAM memory .
Reattach ATX power connector from SMPS to motherbord.
Remove pci cards from PCI slot.
Pull cmos cell from motherbord for 10 minutes so all motherbord settings are defaults.
Reattach both connection to harddisk.
Make sure your harddisk is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then check harddisk is detected.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | HP CTO HP Workstation XW6200 Base...
Xp Pro PCI EXPRESS ATI Radeon will not install Unified Video stream driver for capture card
use latest catalyst driver from amd site on net.
make sure you have at leasdt 2gb system memory.
ok
Sep 15, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
My hp media center pc m8000n has a black screen and the tower beeps
Well, it looks like we can limit the problems to either a motherboard or graphics card failure. Are you able to access the BIOS? Does the monitor say it is disconnected?
Jul 08, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Upgrade for a Ti4200 Graphics Card
i think the best graphics card you can get for your pc cause its AGP slot is a 6200 from nvidia.
May 15, 2009 | Matrix 226R (VPR226R) PC Desktop
One long beep tow short beep
One long beep and two short beeps mean faulty video adapter.
If you are using a card, like a PCI or AGP video adapter then remove and put back the card in slot.
If you have a motherboard, then the video chipset on motherboard had gone, buy an agp video adapter and insert it in the slot inside your computer to fix the problem.
below an example of PCI and AGP video card:
MSI G4MX4000-T64 64 MB Graphics Card
HP Intel DVI AGP digital display card
ATI Rage 128 Pro 32 MB PCI Graphics Card
Mar 09, 2009 | Computers & Internet
Computer wont boot, only fan running
check the (memory) ram chip, keyboards, and mouse for faults then try again.
Most time beeps indicate memory errors
Jan 17, 2009 | Lenovo ThinkPad R61i 14 inch widescreen...
Motherboard problem
These more up to date cards have a special PCI-E connector actually on the card which you have to connect to your psu too.
It shouldnt beep if theres no problems
If you cant get video or anything , make sure that the cardrs power conenctor is plugged into the psu
Jan 07, 2009 | Computers & Internet
Hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Dec 12, 2008 | HP xw6200 PC Desktop
What i have as agp or pci and whats the best graphics card i can get without getting a new pc
An AGP video card would provide a better video performance than a PCI video card.
Jun 06, 2008 | Foxconn (865G7MC-ES) Motherboard
HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop Logo
1,489 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
