Question about Samsung WF337AA Front Load Washer
4e code My samsung washing machine fills with water at the usual speed but after a short time error code 4E is displayed. I have replaced the pressure switch the fault is still there. Can you help with any other sugestions Hi,
  • 1 more comment
  • gina_nagano Jan 01, 2009
    I have the same E4 problem with no manual to find out what E4 means. Can someone help me please and thanks.
  • Souab Khan
    Souab Khan Aug 11, 2013
    E4 means a water flow problem. On my machine the water inpipe had twisted into a knt. Once i ahd straighened it out it was great
  • Dan Baker
    Dan Baker Mar 21, 2016
    For the 4E error code I found that the drain tube was too long and was being submerged in water. I just lifted up the drain hose and haven't had any problems since. It's been a couple months now, it's worth a shot to try and lift up the drain hose before taking anything apart or spending money. I hope this helps some one.
  • 3 Answers
I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
4e code - i_1.gif Make sure the source water faucet is turned on.
Check the water pressure.
http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
Hope this helps.
Posted on Jan 03, 2009
I have problem error 31( E31) please advice me to solve this problem
Posted on Apr 14, 2009
2 Suggested Answers
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
    Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    Dec 17, 2010 | Samsung Washing Machines
    4E showing on Samsung Washing Machine
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 06, 2009 | Samsung WF337AAL Front Load Washer
    The manual says Mke sure the soucre water faucet it turned on. Check the water pressure. turn off water and unscrew the hose from the back of the washing machine. it says to pull out the nesh filter from the end of the hose and ricse it under water until clean with a pair of pliers.also clean the inside and outside of the threaded connector. push the filter back into place, screw the hose back onto the washing maching. turn on the faucet and maike sure the connections are watertight.
    May 15, 2008 | Samsung WF203ANW Front Load Washer
    I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
    Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
    Greetings - Thomas
    Jan 16, 2008 | Samsung WF203ANW Front Load Washer
    Samsung WF337AA Front Load Washer Logo
    5,368 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
