Question about Saitek X45 Flight Control System (J24C) Joystick
Saitek_SST_Software_32.exe install error
Upon downloading the file six times from the actual saitek website, I attempted to search for fixes. This site came up; but I found no fixes for this particular error. At each attempt to install, I receive this message: The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again.
I even tried downloading the XP version and the Vista version. I receive the same error message on each one.
Any help would be appreciated, thank you!
-CG
  • Anonymous Mar 25, 2009
    recieve this message (The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again.)
night71
  • 328 Answers
SOURCE: Saitek X 52
Here are drivers for Vista that would work.
http://www.saitek.com/uk/down/drivers.htm
Just select if you have 64 bit or 32 bit.
Posted on Nov 20, 2007
ser71
  • 818 Answers
SOURCE: The contents of this file cannot be unpacked.The executable you are attempting to run has been corrupted.
When I try to install the software, I get an error message. The installation just quits. trnsp.gif Answer An installation error is defined as any issue or error that prevents the Setup program from fully completing the task. Installation errors can manifest themselves in several different ways. One common installation problem is the Setup program is interrupted with a message indicating some type of problem. Another type of installation error is when the Setup program simply disappears or doesn't complete for any reason. When Setup is interrupted with an error
Many installation issues will be accompanied with an error code and then an error message that identifies the problem. Because the camera software uses the Windows Installer, the exact definition of the problem can be obtained by looking up the error code on Microsoft's website. Two common errors are Error 1904 and Error 2711.
When Setup simply disappears or doesn't complete
Note: When installing software, administrative rights are needed to install all the files for camera software. If you are logged in as another user without administrative rights, the software may not install/function correctly.
First try booting clean. If you are using Windows XP, Windows Me, or Windows 98, click here for instructions on booting clean. If you are using Windows 2000, click here for instructions on booting clean. Once you have booted clean, then try to install the camera software.
Since booting Windows clean may disable CD-ROM support, we recommend you download the latest camera software for your camera and use the download file to install after you have booted clean.
All other installation issues
If you are unable to find a solution to the installation issue given the above information, please try the following suggestions. After each suggestion, try running the installation program again.
  1. Reinstall the Windows Installer. This Windows Installer engine can be downloaded from http://www.microsoft.com/downloads/release.asp?ReleaseID=17343
  2. Windows 2000 Only. Stop the Windows Installer service and reboot the machine. To do this:
    1. Right-click on My Computer
    2. Choose Manage
    3. Click on the plus (+) sign next to Services and Applications
    4. Click on Services
    5. On the right side on the pane, double-click on Window Installer
    6. Choose STOP
    7. Reboot the computer.
If the service was already stopped, try starting the service, then stopping the service and rebooting.
If following through on the specific instructions above do not resolve the issue, please try the following standard diagnostics:
  1. Try a different installation media. For example, if you are attempting to install the camera software via the CD, download and install the latest web release. If you are trying to install the web release, try the camera software CD. Please note, the latest software can be downloaded here.
  2. Run ScanDisk and Disk Defragmenter. Both of these utilities can be found in the Accessories program group of the Windows Start Menu.
  3. Search for and delete all TMP or CHK files.
    For Windows 98 and Windows Me Users:
    1. Click on "Start", "Find" and choose "Files or Folders".
    2. In the Named field, type *.TMP and click "Find Now"; delete all files found.
    3. Repeat this procedure with *.CHK.
    For Windows 2000 Users:
    1. Click "Start", "Search" and choose "For files or folders".
    2. In the Search field, type *.TMP and click "Search Now"; delete all files found.
    For Windows XP Users:
    1. Click "Start", "Search".
    2. In the "All or part of the file name" field, type *.TMP and click "Search;" delete all files found.
  4. Empty the TEMP directory; this folder may contain files that are interfering with the installation. To do this, use the following steps:
    1. Right-click on My Computer and choose Explore.
    2. Click on the plus (+) sign next to the C drive.
    3. Click on the plus (+) sign next to the Windows directory. (For Windows 2000, it is the WINNT directory.)
    4. Click on the plus (+) sign next to the Temp directory. The right side of Explorer will display the contents. Select all the files listed in the Temp folder and delete them.
  5. Reboot the system and try installing the software again.
Posted on Feb 29, 2008
SOURCE: not working help
joypad doesn`t work well ob fifa 09
Posted on Oct 21, 2008
SOURCE: Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
Posted on Jan 18, 2010
SOURCE: i have a Saitek P3000 gamepad, cant turn on?
i can not charge my batteries and i dont know how to turn it on
Posted on Dec 24, 2010
Have a Saitek FPS P990 thought I got the right software and drivers download "Obviously Not" tried Google and a no tracker search engin both with about same results want to wane looking maybe if...
Found it for you!
Go to http://www.saitek.com/uk/down/drivers.php
On the box that says "Choose your product type" click on gamepad.
Then on the box "Select product" pick P990
Then on "Select Operating System" pick Win7/vista 32 bit.
It will give you options to download both the software and the driver.
This is from the manufacturer website so it should work perfect and be the right one.
Apr 09, 2013 | Computers & Internet
Not working with windows 7
You can download the driver software from the Saitek website, here's the link http://www.saitek.com/uk/down/drivers.php
Just select Joystick in the first drop down box, then your version of windows 7 (32 or 64 bit) then just follow the instructions to download your drive.
Install the driver before you plug in yours joystick (the driver will more than likely ask you to plug it in at some point in the install process).
I hope this help you out.
Jan 16, 2011 | Saitek ST290 Joystick
The official Saitek website only has the drivers for the X52 Pro and so though I only have the standard X52 (not the pro), I used the Pro driver and software. The profile editor does list the standard X52...
Saitek has drivers for the X52 on their website.
Here are some direct links.
XP 32bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_32.exe
XP 64bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_64.exe
If you need further help please let me know.
Hope it helps...
Sep 24, 2010 | Saitek X52 Flight Control System
It turns on but it does not work in the saitek pro flight switch panel
You need to load the disk that came with the switch panel. Look in the directory where it installs and you will see a file in there that forces the program to load. Note: It is not the main exe file.
Jun 27, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek P990 Game Pad Install Error
you probally need a different driver then. google it.
if your runnin windows xp open task manager and if you do have the process IMGJTM.exe running end it immediately, all it does is screw you up on the Inputs for all devices including your keyboard if its usb
Sep 27, 2009 | Saitek Dual Analog P990 Game Pad
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
Windows 98 drivers for Saitek AV8R joystick
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Saitek Aviator AV8R Joystick
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Saitek X45 Flight Control System (J24C) Joystick Logo
160 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
