Question about Zenith B25A74R 25" TV
No color plugs for tv
I have dvd player trying to hook up to old tv the tv doesnt have any plugs in the tv like red white yellow only has cable hook up what do i do
  • Zenith Master
  • 5,138 Answers
Go to Wal-Mart or Radio Shack to get IF converter hookup for DVD you can plug TV& dvd Jacks into this.
Posted on Dec 26, 2008
Compatability with magnavox combo dvd and vcr
the back of the vcr/dvd player will have some rca plugs that are red,yellow,white,they will be labeled out putthe yellow is video,the red and white are left and right audio,the back of your tv should have the same thing,it should say input,get a rca cable with plugs on both ends and match the plugs to the colors,if you tv or dvd player,doesnt have these,then you will need to plug your cable box into the dvd player and run a coaxial from the dvd player and tv,use channel 3 or 4 on the dvd player and 3 or 4 on the tv
May 08, 2015 | Magnavox Televison & Video
Cant get DVD to play how do I hook it to my TV
depends on the tv and dvd player. old dvds you plug in the cable with three colors. red white and yellow to the tv input of the same color. now a days dvds and flat screens use the hdmi cable.
Dec 04, 2013 | Audio Players & Recorders
Trying to hookup a dvd player model #DX-DVD2
You need 3 RCA plugs... generally colored red, white, and yellow. on the back of the DVD player plug the yellow to video out, the red to audio out (stereo), and the white to audio out (mono). The other side of them goes to the back of the TV... the yellow video input 1, the red audio (R) input 1, the white Audio (L) input 1. Then take the cable service round coax cable and screw it into the back of the DVD unit where it says Coax. Get another short coax cable and hook to back of the DVD unit on Cable out, and the other side to the back of the TV under cable/vhs. And that"s it! Hope that helps you!
Chuck
Jun 23, 2012 | Dynex DXDVD2 Player
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Hook up
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
Oct 24, 2008 | Philips Magnavox MWD7006 DVD Player
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
Zenith B25A74R 25" TV Logo
140 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
