Question about Garden
Cord stayes out motor not running
Brand new whipper snipper homelite brand cord will not go back in
  • 17 Answers
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Posted on Jan 08, 2009
Primer bulb for mightlite whipper snipper who can fix, Gailes.
It is pretty easy to fix if you are the least bit handy. Order what you need from Amazon or your local service center.
Or, contact your local Homelite retailer/service center directly or online here: https://register.homelite.com/sign-in
Feb 07, 2018 | whipper snipper Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
What is the correct fuel oil mix for a homelite whipper snipper
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
Mar 20, 2010 | Homelite Expand - It Brushcutter...
Homelite whipper snipper is hard to start and its new petrol mix is correct
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Sep 14, 2009 | Homelite Garden
Garden Logo
304 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
