Question about Sony Playstation 3 (PS3) Console
How do you plug-in the cable cords in the tv for the PS3?
Do you use all of them or what? and which video1, or 2 do you plug it in
    Problem Solver:
What cords are u using three or five comp?
Posted on Dec 26, 2008
  • justluck79 Dec 26, 2008
    doesnt matter its up to u on which one either should work!
I have a panasonic Th-42pv500a. I'm trying to connect my ps3 Via HDMI but it won't work. The ps3 works in my other tv with the same HDMI cable. And the foxtel box works in the panasonic with the same HDMI...
the playstation detects that you are changing display settings. hopefully you still have the old red yellow and white cord that we all used to use to plug in stuff to your tv . use this cord to connect your playstation to the tv, it should pop up that you want to change display settings. then after you go through that unplug and recconect the hdmi and it should run you through it again, Another option - when you plug in your ps3 to the tv , turn everything on the tv and playstation. if nothing pops up turn off your tv and playstation , literaly unplug them from the outlet for a good minute then plug everything back in and you should fix it that way. hope one of these work
May 04, 2011 | Televison & Video
When I turn my ps3 on I get no video on my tv and I just bought the wire so its not the wire... How can I fix this?
Obviously, first make sure the PS3 and television/projector are actually on. Then confirm the television actually works, and that the port you're connecting to on the TV works (connect another console, for example).
You should then make sure all cords are firmly attached to the PS3 and you television.
If the cables are snugly in place and you still have the issue, you should make sure the PS3 is outputting the correct video. To do this, power off your system, then press the power button to turn it on, but keep it held down for a couple of seconds (around 5 seconds I believe). It should beep and your video settings will be reset.
Still nothing? Make sure the cables are working. Swap them out with cables you know that work, or test the cables in question on something else (another PS3 or old PS2 for the regular cable, anything that has HDMI out for the HDMI cable). I know you said it's not the wire but you should confirm it because the next solutions are kind of a last resort...
You might have to send it in to Sony, which can be done here. They take forever to send it back though, and if you're out of warranty it costs $150 (it's free if you're under warranty though!).
Alternatively, if you're awesome and feeling adventurous, you can fix it yourself. Here's a guide, and more can be found online.
Regardless, hope everything works out!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
How to connect samsung dvd surround to my tv to get sound
if your tv has a digital out jack and your samsung has digital in jack use an optical cable. if your tv have analog jacks (Red and White) use audio out from tv to audio in on samsung surround, labeled video1,2 or aux
Oct 21, 2009 | Samsung HT-Z310T Theater System
PS3 Power Surge Help!
hi there try using the ps3 as audio-cd play(blind, without screen)
with any other tv to make sure soun still is coming...
if there was a flash or circuit destroyíng the yellow(video)plug,
either the cable has been destroyed or the short backfired even into the video module of the psx3.
try exchanging the cable, if that doesn't do any good, the video module got smoked...
let a technician repair/replace it or you think about becoming the happy owner of another brand new psx3
good luck!
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Sparks during hookup
u have a grounding issue with either ur cable or dish box,.and if u plug anything up to it it will spark adn shock and if u do it over and over it will fry the system,. hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 sounds like its reading the disc but nothing appears
try a new cord, ir maybe the storm fried the tv inputs.
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Hdmi cord causing purple and green lines
It may be a ground loop caused by cable televisoin and the Ps3, as PS3 uses a 3 prong plug. Try unplugging the ps3 power cord and see if the lines go away. If they do, it is a ground problem...usually with cable tv. If this is the case, try a good quality power bar with cable suppression jacks on it. It will help eliminate the ground loop in most caese.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
15 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
