Question about Jabra BT350 Bluetooth Headset Headset
Setting up Jabra VBT2050 Bluetooth
Need help to find out how to set up Jabra VBT2050 Bluetooth to my US Cellular Motorola Razor V3M
  • 3 more comments
  • Anonymous Jan 08, 2009
    my dad lost the instructions for this bluetooth. how long do you have to hold it in order for the headset to pair?
  • Anonymous Jan 12, 2009
    same here... It continues to tell me that it is empty and I don't know where to put the code...
  • skammer604 Jan 22, 2009
    trying to actually turn on the bluetooth in discoverable mode so phone can pick up. sister doesnt have directions for it.
  • Anonymous Mar 15, 2009
    What is a "passcode"
  • Anonymous May 05, 2009
    0000 does not pair my headset to my Blackberry Curve
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Posted on Jan 07, 2009
0000 is the correct paskey, but to have your phone recognize the jabra you must hold the Jabra call button until the light stays steady, then phone will recognize bluetooth and allow you to enter passkey & pair the phone & device.
Posted on May 15, 2011
I need a pass key to pair my bluetooth VBT 2050 Jabra. Any help?
Posted on Jan 05, 2009
JABRA VBT2050, Pairing key is 00000. Five Zeros.
Posted on Sep 14, 2009
Having problems setting up my 2040 [HELP} mopass@peoplepc.com
Posted on Jan 20, 2009
I recently got the Motorola Droid X and paired & connected by jabra vbt2050 with it and it worked. Today though, when placing a call with the Jabra, I could hardly hear the call. Now I have not power...
To see if the problem is with your bluetooth connection, try sending and recieving files with your bluetooth. If it is successful, then try borrowing 1 jabra device and test it with your phone. The bluetooth connection and the jabra device are the problems I can see since you said it worked once.
Hope this helps! -jayps
Mar 09, 2011 | Cell Phones
Trying to pair my Jabra VBT2050 to my motorola. The passkey 00000 isn't working
you can only use one digit number not four digit..to detect the bluetoot headset
Sep 30, 2010 | Jabra BT350 Bluetooth Headset Headset
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
Can't connect
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
Cheers!
Jun 10, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Jabra BT350 Bluetooth Headset Headset Logo
8,040 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
