Question about Apple Radeon 9000 Pro Mac Edition Graphic Card
DVI-I or DVI-D?
Some cards with DVI have 8 column of holes, but my connector wires has 6 (two groups of 3 each), are these different types and are they useable together (compatible?)
  • 1,602 Answers
You have to get the pin out diagram for the connect and the pplug and if you dont want to do the work yourself there are places that specailizes in these type of matter, you tell them what you and what youneed it to do and they make the cable for you and there are not that exspensive, the costs are low.
computer cable specailist, or cable america, cables to go.
rod
Posted on Mar 03, 2009
Where do the p3,4,5and 6 go in the computer
If you go to the Dell support site you can download the manual.
Apr 09, 2013 | Dell OptiPlex GX520 PC Desktop
How to replace ignition lock cylinder
This may or may not help,but i found this
REMOVE OR DISCONNECT
1. Disable the SIR System.
2. Battery negative cable.
3. Knee bolster and IP steering column reinforcement. NOTICE: The steering column should never be supported by only the lower support bracket alone, damage to the column lower bearing adapter could result.
4. Lower support bracket from vehicle (2 bolts).
5. Upper column support from IP (2 bolts).
6. Lower steering column so that it rests on the driver seat.
7. Ignition switch wiring protector.
8. Ignition switch retaining screw and nut.
9. Ignition and turn signal switch column harness connectors from IP harness.
10. Turn signal switch connector from column harness.
11. Ignition switch, harness, and connector. Important
o DO NOT splice ignition switch wires.
INSTALL OR CONNECT
1. Ignition switch, securing with retaining screws.
o Adjust ignition switch. Steering Column Unit Repair.
2. Turn signal switch connector to column harness.
3. Ignition and turn signal switch column harness connectors to IP harness.
4. Ignition switch wiring protector.
5. Raise steering column to support bracket.
6. Two bolts to upper support bracket. Do not tighten fully at this time.
7. Bolt and nut to lower support bracket.
o Align column to instrument panel opening. A small shim (wedge) placed between the instrument panel column support bracket and the column can be used to hold the column stationary while tightening the upper support bolts.
o Upper and lower column support bolts and nuts to 27 Nm (20 ft. lbs.).
8. IP steering column reinforcement plate and knee bolster.
9. Battery negative cable.
10. Enable the SIR system.
super vag k+can v4.8
Jul 30, 2012 | 1994 Geo Prizm
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
I just want to know if this card has a 2 or 3 pin audio connector on it anywhere. i want to purchase one but not without some type of audio capability on the the card.EVGA 512-P3-N982-B2
No present video card has audio circuits/connectors on it. You are probably referring to a Home Theater card with VIVO capabilities- this is something totally different, completely unrelated products. A combination of both has been produced in low quantity in the past , but not in the last 8 years.
If this is the case then you will need 2 separate cards.
Apr 12, 2011 | Smith System EVGA 512-P3-N982-B2 GeForce...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DFid something, In my CPU i dont have the slot for the other type DFi, ...
I believe you are referring to a DVi connector. We have different types of connectors but none of them is DFi. We have VGA, HDMI, SATA, and DVi connectors. Here's a cheklist of what you need to do:
  1. Check the connector of the computer whether you have VGA, HDMI, SATA, or DVi
  2. Check the connector of the monitor whether you have VGA, HDMI, SATA, or DVi
  3. Now that you know the type of connectors you have for your system, you know what cable to buy.
It does not really matter if your computer and monitor have different connectors. We can purchase cables with VGA - VGA, HDMI - HDMI, DVi - DVi, VGA - HDMI, VGA - DVi, HDMI - DVi. So, don't worry and thank you for choosing FixYa!
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Does the Compaq s3310cl support a DVI monitor? I am looking at the Samsung 2243swx but it's only a DVI monitor and has no VGA capability. I can't find any info on whether my computer supports this kind of...
Hello, the integrated video card in the Compaq s3310cl doesn't have a DVI port, however you may purchase and DVI to VGA adapter which should allow you to hook up that Samsung 2243swx Monitor. Be aware there are various types of DVI connectors so match up the connector you require for you Samsung Monitor.
d8b8bed.jpg Thanks
Ryan
Cobalt Systems
DVI Connector Guide DVI-D Single Link DVI-A DVI-I Single Link Digital Only Analog Only Digital & Analog dvi_ds.gif dvi_a.gif dvi_is.gif Two sets of nine pins, and a solitary flat blade One set of eight pins and one set of four pins, with four contacts around the blade Two sets of nine pins and four contacts around the blade DVI-D Dual Link DVI-I Dual Link Digital Only Digital & Analog dvi_dd.gif dvi_id.gif Three rows of eight pins and a solitary flat blade Three rows of eight pins and four contacts around the blade
Sep 21, 2009 | Compaq Computers & Internet
DVI-I or DVI-D?
if i rember correctly if a card supports DVI-D and a monitor only supports DVI-I you can just use a DVI-I cable and it should work.
Dec 26, 2008 | Apple Radeon 9000 Pro Mac Edition Graphic...
Changing default paper size
Press & hold shift then press sel to enter menu mode. Press group until the group you wish to change appears in the first column. Press item until the item you wish to change is in the second column. Press set until the setting you want appears in the third column. Press and hold shift then press sel to exit & save your settings.
The default page sizes are; 11", 11-2/3", 12", 14", 17", 5", 3", 4", 5.5", 6", 7", 8", 8.5".
Jun 19, 2008 | OKI MicroLine 420 Matrix Printer
Apple Radeon 9000 Pro Mac Edition Graphic Card Logo
66 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
