Question about Apple Radeon 9000 Pro Mac Edition Graphic Card
DVI-I or DVI-D?
I'm looking for a video card with DVI-I (I think) and I see some that have a different type of connector that the wires I have. Mine has 6 columns of pins (two groupings of 3) while photo of some cards show connectors with 8 columns. ARE these compatible or do you need exact matches, is mine DVI-I?
    Scholar:
  • 191 Answers
If i rember correctly if a card supports DVI-D and a monitor only supports DVI-I you can just use a DVI-I cable and it should work.
Posted on Mar 17, 2009
How to install a female DVI to my computer
If you are trying to connect a monitor that has only DVI connections to an older PC that only has VGA-15 pin, the easiest solution is to buy a replacement video board that has DVI capability. However, ensure that the DVI is of the same TYPE as the monitor. There are a number of different DVI configurations, and they are not all compatible with each other. There are VGA-to-DVI adapter cables, but they only work if the DVI is DVI-A or DVI-I, since the VGA port is analog and not digital.
Here is a link to the different DVI configurations. You can compare them to the connector on your device to see what type you need. If it is a digital-only type, you will need either a new video card that supports digital or you need to get a analog-to-digital converter cable. They are more than just an adapter; they have electronics that convert the signal.
https://www.l-com.com/multimedia/tips/tip_dvi_config.pdf
Oct 27, 2016 | Computers & Internet
A blue display box continually pops up with Input Select D sub DVI. I am thinking it is something to do with the monitor. What is wrong?
This monitor has two types of video inputs, a 15 pin VGA D-sub connector and a DVI connector.
If the video card has a 15 pin D-Sub then connect the video cable to the 15 pin D-Sub connector on the monitor.
If the video connectors are DVI then connect the video card and monitor with a DVI video cable.
You will also need to configure the monitor for either the D-Sub or DVI video input.
Aug 03, 2011 | BenQ FP91G+ 19" LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DFid something, In my CPU i dont have the slot for the other type DFi, ...
I believe you are referring to a DVi connector. We have different types of connectors but none of them is DFi. We have VGA, HDMI, SATA, and DVi connectors. Here's a cheklist of what you need to do:
  1. Check the connector of the computer whether you have VGA, HDMI, SATA, or DVi
  2. Check the connector of the monitor whether you have VGA, HDMI, SATA, or DVi
  3. Now that you know the type of connectors you have for your system, you know what cable to buy.
It does not really matter if your computer and monitor have different connectors. We can purchase cables with VGA - VGA, HDMI - HDMI, DVi - DVi, VGA - HDMI, VGA - DVi, HDMI - DVi. So, don't worry and thank you for choosing FixYa!
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Does the Compaq s3310cl support a DVI monitor? I am looking at the Samsung 2243swx but it's only a DVI monitor and has no VGA capability. I can't find any info on whether my computer supports this kind of...
Hello, the integrated video card in the Compaq s3310cl doesn't have a DVI port, however you may purchase and DVI to VGA adapter which should allow you to hook up that Samsung 2243swx Monitor. Be aware there are various types of DVI connectors so match up the connector you require for you Samsung Monitor.
d8b8bed.jpg Thanks
Ryan
Cobalt Systems
DVI Connector Guide DVI-D Single Link DVI-A DVI-I Single Link Digital Only Analog Only Digital & Analog dvi_ds.gif dvi_a.gif dvi_is.gif Two sets of nine pins, and a solitary flat blade One set of eight pins and one set of four pins, with four contacts around the blade Two sets of nine pins and four contacts around the blade DVI-D Dual Link DVI-I Dual Link Digital Only Digital & Analog dvi_dd.gif dvi_id.gif Three rows of eight pins and a solitary flat blade Three rows of eight pins and four contacts around the blade
Sep 21, 2009 | Compaq Computers & Internet
What video card can I upgrade to MSI Part No: MS-6566E-010
Here's the best recommendation I can give you:
Your motherboard supports both AGP and PCI. Because of the fact that you have AGP, you could go that route for a video card. If you look at this link, you'll see different types of video cards that will work with the AGP slot. The other thing to consider is the output. If you don't have a monitor that supports DVI (white wide connector with 24 pins) then your choices are narrowed to VGA (blue 15 pin connector. First let's look at the AGP cards:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318
You'll notice that some have more memory than others. The ones with more memory are better with respects to being able to process more video within their own GPU(graphics processing unit)
Some of the cards have DVI and VGA video out. Some of the cards have only DVI out. Not to worry because most cards have a DVI to VGA adapter. It won't run in true DVI output, but that's okay. If you have a DVI monitor, then you're in luck!
PCI - PCI cards are getting more rare to find since the newer technology is all PCIe or PCI-x, which your motherboard does not support, so your choices will be more limited. You can look at some options here:
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards&
Again, any of these will work too. It's going to come down to basically preference. AGP is just as good in MY opinion as PCI. Things to consider when buy the new card are:
1) Reputation of vendor/manufacturer
2) Price
3) Warranty
4) How good is their support is you have an issue (Of course you always have us here at FixYa)
I would be glad to give you a yeah or nay once you narrow it down. Also, if you like, you can read a little bit more about DVI here: http://www.connectworld.net/cis/digital-monitors.html
Monitors that support DVI are more affordable and offer superior output resolution as opposed to VGA. I hope I've helped and if you need any clarification, just add a comment and I will be glad to respond.
Best Regards...Jerry
Apr 29, 2009 | MSI ms-6566e-020 845e Motherboard
I have a new graphics card and the connections dont match
the motherboard might be VGA, and the card PCIE, the connectors will not match, more info is required, better still check motherboard specifications, and look for the right type of graphics card.
Jan 25, 2009 | Computers & Internet
DVI-I or DVI-D?
you have to get the pin out diagram for the connect and the pplug and if you dont want to do the work yourself there are places that specailizes in these type of matter, you tell them what you and what youneed it to do and they make the cable for you and there are not that exspensive, the costs are low.
computer cable specailist, or cable america, cables to go.
rod
Dec 26, 2008 | Apple Radeon 9000 Pro Mac Edition Graphic...
Video Input Selection Problem
That is due to the fact that you can only connect 1 desktop to the HP LP2465 as most monitors.
For one the LP2465 does not have the picture in picture technology and for another the two ports you are connecting your Macs into are DVI (Digital Video Interface) connections. One is the Single DVI and the other is a Dual DVI.
It does not mean you can connect two Mac computers to the same display and both work. That is not practical because there is only one video input interaction possible with a computer and a monitor.
The DVI connections are determined by their ability to use either Analog and Digital signal transmissions through one connector.
So in order to effectively use your HP LP2465, you can only use 1 computer with the monitor because it is not designed to work with two computer graphics cards at once. Most LCDs have only one DVI or VGA connector to connect to a computer- your just happens to host two types of DVI connections is all..
That is the reason one computer is on with your display and the other is not displaying any video.
Take a look at this great explanation of the differences between Single DVI and Dual DVI connectors via this link:
Digital Video Interface (DVI)- Defined
Regards,
-Terry
Feb 13, 2008 | HP Lp2465 24 in. Television
Apple Radeon 9000 Pro Mac Edition Graphic Card Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
