Question about Garmin Quest GPS Receiver
Replace garmin quest battery
How do I remove or replace the battery?
Where can the battery be found after opening the unit.
Can it be easily taken out and replaced.
  • headbeep Dec 29, 2008
    I have the same problem! Unit is about 3 years old. Love the unit, but I think they charge around $100 to replace the battery!
    Steve
    headbeep@msn.com
  • 24 Answers
Instead of retyping everything. I outlined it here-
http://www.fixya.com/support/t3909146-change_battery
Posted on Jan 23, 2010
Garmin quest batteries
I have seen replacement batteries for the Quest GPS units on Ebay. Search for "Quest Battery" or "Quest GPS Battery". You may need to narrow your search but that will point you in the right direction. Another source is Batteryship.com. I have bought several batteries from them and have found their service outstanding.
Apr 05, 2011 | Garmin Quest GPS Receiver
My garmin quest will not come on even when powered by the car cradle. It flickers for a brief second, then fails.
This sounds like an old battery that has deteriorated to the point where the external power won't even turn the unit on. I have a fairly detailed description on FixYa of how to replace the Quest battery. Search for something like Quest Battery. It does involve opening the unit up. If you are not comfortable with the inner workings of electronic equipment, you will need to return it to Garmin.
Apr 06, 2010 | Garmin Quest GPS Receiver
How to change battery on my old Quest? And what type of battery do I have to bye?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
After plugging the new battery in, you may want to use a small dab of glue to secure it to the back side of the unit like the original battery. Reassemble the unit, reversing the process with the front and the back. The Quest units have a rubber sealing gasket between the two sections. Be sure you inspect that for kinks before tightening the 6 small screws. I would suggest the screws be tightened down gradually so uniform pressure will be applied to the gasket. I would tighten one screw down partially then move to the opposite side and criss-cross the unit until all screws are snug. Again, inspect the gasket for proper seating and you are done.
Jan 17, 2010 | Garmin Quest GPS Receiver
How do you change lithium ion battery in garmin streetpilot c530
The unit can be opened by removing the frame around the screen. However if you are still under warranty you will void it. The battery is not an easily replaceable one since it is soldered into the unit but if you are hany with a soldering iron it is fairly straightforward. However you have to find the correct battery which you can do with an online search.
Nov 01, 2009 | Garmin StreetPilot C330 GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Where is the battery in the garmin quest
The battery is in the back side of the unit and is glued into place. It has a red and a black wire coming from it to a small plug that plugs into the main circuit board.
Dec 25, 2008 | Garmin Quest GPS Receiver
Garmin Quest 2 GPS
www.batteryship.com. Look on the screen for "GPS Devices". Click on that and it will take you to a page of pull down menus. Find the Garmin menu and just look for "Quest". Battery is about $25.
Dec 18, 2008 | Garmin Quest 2 GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Do you know where you got your battery?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices2_bing.gif, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
May 30, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
144 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
