Question about Canon PowerShot A590 IS Digital Camera
My a590 digital camera has lines on the lcd display after it banged on the counter
  • dzimarek Jan 17, 2009
      The LCD has fine vertical lines and the top half is basically whited out.  Is this fixable?
  • 30 Answers
Hi There, If your screen still lights up, the LCD panel is probably cracked. Take to shop for estimate: Around $120.00 for repair.
Thanks, mr cicmo
Posted on Dec 26, 2008
Function buttons not working on canon a590
Since CHDK changeset #917 the <Alt> button can be set to PRINT (default) or DISPLAY from the "Miscellaneous stuff" / "<ALT> mode button" CHDK menu
  • If DISPLAY is selected for <Alt> button: press DISPLAY quickly it will act as your <ALT> mode button, but if you hold it down for a second, it acts like the DISPLAY button normally does
Performance chip
May 23, 2012 | Canon PowerShot A590 IS Digital Camera
The LCD on my A590is camera doesn't work. When I
if the lcd is flexible then mostly the problem is with lcd connector.if you have a v cable then connect it to tv and see if picture is coming, if it comes then connector is faulty for sure
May 28, 2010 | Canon PowerShot A590 IS Digital Camera
Lens error restart camera
your cam is out off order
if want it back needs to replace optical block
assembly that is the only way.
good luck..
Feb 26, 2010 | Canon PowerShot A590 IS Digital Camera
Canon powershot a590 IS lcd screen
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Nov 05, 2009 | Canon PowerShot A590 IS Digital Camera
My powershot A590 lens are open but it wont turn on
Can it take pictures? It may be that your LCD screen is disabled, This can be Un-Done by pressing the "DISP" button a few times.
Aug 11, 2009 | Canon PowerShot A590 IS Digital Camera
Can't download. Get "Communication Error" message on Canon A590
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 15, 2009 | Canon PowerShot A590 IS Digital Camera
Canon powershot A590 displayes lens error, restart camera.
I had this problem. Nothing was lodged between the body and lens, restarting multiple times did nothing, cleaning, torquing, twisting over several days - nothing.
So, figuring "what could it hurt?" I just smacked it on the heel of my hand a couple times. Now it works.
firm percussive maintenance saves the day once again.
Dec 27, 2008 | Canon PowerShot A590 IS Digital Camera
Lcd doesn't work
While in shooting mode, set dial to stitch and then press menu. That's the only time my screen works, and the only way I can make changes.
Dec 08, 2008 | Canon PowerShot A590 IS Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
