Question about Acer Aspire T690 (AST690UP820A) PC Desktop
The DVD drive status: This device cannot start. (Code 10)
Acer Aspire T690 PC desktop
Driver software cannot be loaded.
Found that hard disk location: location 0 (channel 0, target 0, Lun 0) is the same as the DVD.
  • 1 more comment
  • g_l_watson Jan 16, 2009
    dvd does not work tells me code 39 driver is corrupt or missing
  • Anonymous Apr 02, 2009
    The DVD drive status: This device cannot start. (Code 10)"from regeit i deleted the upper filters and lower filters then also the same message is coming
  • varier May 11, 2010
    Whats the Error code can you be more specific by going into properties of the DVD drive....
    thanks,
    Swapnil.
My wifes computer has had the same problem. It's a driver problem and I found the fix on Acer website. See if your computer is listed on the following link. If so, download the patch. This totally solved my problem! http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4087&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
Posted on Apr 03, 2009
    Novelist:
    Champion:
  • 233 Answers
Go into DEVICE MANAGER and check both the hard drive and DVD. Sounds like you have a hardware conflict, that is both are competing for the same territory (IRQ). You should be able to change this setting manually in there.
Posted on Jan 01, 2009
My computer is acer aspire acer t690.do you think it is harddrive
it looks like sata
Aspire T690 Specifications
Part Number: AspireT690 Aspire T690
Storage CD-ROM, CD-RW, DVD-ROM, DVD/CD-RW Combo, DVD Dual, or DVD Supermulti (varies by model)
Up to 400GB Hard Disk Drive SATA (varies by model)
9 in 1 Card Reader (selected models)
Oct 14, 2012 | Acer Aspire T690 (AST690UP820A) PC...
My acer t690 is shuting down for no reason i think hard drive is going when i buy new 1 can i install and use vista straight away as my pc wont let me burn a copy of the factory default disk wat do i...
Sounds like a thermal problem. If the PC shuts down unexpectedly, I would make sure the CPU cooling system is clean of dust especially the fan.
Does not sound like a hard drive problem.
-AAT
Feb 21, 2011 | Acer Aspire T690 (AST690UP820A) PC...
No sound after installing window 7 starter, driver installed with vista do not recognize the drive software.
You must download the correct drivers for audio, video, hard drive and mother noard.
Go to Acer.com and there is a menu system that will lead you to them.
Hope this helps
Jan 04, 2011 | Acer Aspire T690 (AST690UP820A) PC...
CD Driver not being recognized, went into device manager and under device status it says, "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)
this is a tough one. I found this at acer:Optical Drive
8X DVD-Super Multi double-layer drive or DVD/CD-RW Combo
(varies by model)
The bad news is the part where it says varies by model. You will need the exact model of the drive to get the proper driver for it. My advice is to take it to an Acer shop and ask them to identify the cd drive for you.
May 06, 2010 | Acer Aspire 3680 Laptop
Vista was pre installed on my pc how do i install a clean copy on my hard drive with no disc?? i have an acer aspire t690
A friend of mine had that problem. She contacted Acer and said she did not have a chance to make a backup disk and she needs to re-install the operating system. Within a few days Acer sent her the backup disks.
Just call Acer and ask for it, like she did. If that should not work for you, come back and someone will walk you through to put a copy of your drive on a cd. Hope things work out for you!
Oct 13, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Want to rest to factory default settings
If it came with a system restore disk, make sure your PC boots to the optical (DVD) drive and follow the prompts. If your desktop did not come with a CD, then everything is on another partition on your hard drive, in that case, when you PC boots up, you should see something along the lines of system restore.
Mar 20, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Cd/dvd drivers missing on vista 32 install
The best way to find out if you need SATA or IDE is to open the case and look. If you have gray cables about one-inch wide with a red line on one side then that is IDE. They are parallel cables. If you have anything else then it is SATA which is a serial cable. I have never been to the Acer Website but I know on Dell, HP, etc. they have a place under support and drivers that you can go. Type in your model number and download the drivers. I don't know if you have another computer to do it, but unfortunately if your restore disk do not work then that is where you will have to go...also see if you can contact someone at Acer and find out why your restore disk do not work. I have wiped my hard drive clean and I was still able to re-install the revovery disk.....Hope this helps.
Don't forget to rate this solution before you log out.
Jan 27, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Audio Dead/silent
If you can open CPU casing the look under the motherboard, see if you can find the Chipset of your Sound Device, it is usually start with ICON and Model Number, like ADI1987, CMI3798, something like that. And if you found it, then post the chipset model and i will be happy and glad to help you find the proper driver for it.
-mrsolution.
Jun 11, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Computer rebooting
go to start, control panel, system, hardware, device manager, then click the drive thats doing tis under disk drives or cd dvd, repair the drive, if that doesnt work uninstall it then reinstall it, or reinstall it from the last point it worked. let me know
Sep 19, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Acer Aspire  T690 (AST690UP820A) PC Desktop Logo
618 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
