Question about T-Mobile Sidekick® 3 Cellular Phone
Screen I had a sidekick given to me and it turns on but the screen is just blank. It doesnt light up or anything but the buttons do. How can i fix the problem
    President:
  • 625 Answers
Is it white or dark?
If blank white, then the cable needs to be reset if dark then the lcd screen needs to be replaced. They are easy to change and run about 35 dollars for the whole assembly.
Here is a guide for that
Sidekick 3 LCD replacement guide
and here is a link to see what is availble on ebay:
Sidekick 3 LCD Screen
Hope that helps
Posted on Dec 26, 2008
Sidekick Gekko Wont Turn On
try to charge phone battery in 12 volts dc
Jul 17, 2009 | T-Mobile Sidekick ID Cellular Phone
My screen is blank
Is the screen white or just dark?
Fix Sidekick White LCD Screen
If it dark or no light at all then
replacement of the Sidekick 3 LCD flip screen.
to buy a sidekick 3 lcd screen look here.
http://www.repairmysidekick.org/Sidekick-LCD-Screens/buy-a-t-mobile-sidekick-3-lcd
Look for one that has the torx screwdriver included
Jul 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID screen
Call t-mobile if the phone is stillunder warranty
If not then follow this procedure.
It will usually fix the problem
Jul 05, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick screen blank
Call T-mobile if the phone is still under warranty. They may fix it for you.
If not follow this procedure, it usually works.
Sidekick wont turn on
So take it to a mobile service center and have the phone check to see if you might have not put a cable back in the correct place.
Jun 16, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lights don't turn on
You need to replace you LCD. About 50 bucks from ebay. most come with good instructions and the screwdriver. You will need a T6 Torx driver to open the LCD.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Really need help please
In both cases you lcd screen has died, the backlight will usually go first.
Fixing them is easy, a new lcd screen assy can be purchased from ebay for less than 45 dollars. It only take the removal of 2 screws to replace it. Read throught the procedure below.
Sidekick 3 LCD Flip Screen Replacement
Here is the link to new screens
Sidekick 3 LCD Screens for sale
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID blank screen
if you wiggle around the flexi cable in back of the screen it might flicker on again.
mine was faded but i was still able to see the screen .. i messed with it & it worked.
if you don't trust that way rotate the screen 90 degrees
unscrew it [MAKE SURE PHONE IS OFF!] your going to need a torx wrench, a really small 1.
take the screen off it & undo the back side of the screen & fix the cable that way.
~GL~
Jan 22, 2008 | T-Mobile Sidekick ID Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
220 people viewed this question
Top T-Mobile Cell Phones Experts
ismael castillo
Damen Wong
Damen Wong
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
