Question about HP Pavilion Ze4900 Notebook
Can't get past log on screen on HP laptop
I'm trying ti fix a laptop for my in-laws! Please help!
It starts up and then brings me to a screen where I can choose a user name to log-on. It won't let me log on under any of the user names, including 'guest' and I get this message
"The system cannot log you on due to the following error:
The specified domain either does not exist or could not be contacted
Please try again or contact your system administrator."
When I tested the hard drive I got a "#2- 07 fail" message
Is there anything I can do?
  • 6 more comments
  • goddessnike1 Dec 26, 2008
    Ack, sorry, it's running Windows XP, but I have no idea which SP. My in-laws weren't using it for a long time because for awhile they couldn't get it to turn on at all.
    The one built into the BIOS gave me the HD error.
    There shouldn't be any domain or workgroup, unless it's the wireless network they used to have in their house.
    I booted the computer in safe mode and still can't log on as an administrator. I seriously doubt my ILs would have any idea how th change the admin password, so I don't know what's up with that.
    I have the XP disc, yes.... I was hoping it wouldn't come to that.
    frcs68 - When I choose 'options' the only thing is does is bring up a 'shut down' button with is either active or grayed out depending on in which mode the computer was started. I can't change domain, it's not an option.
    ebelingbl
    ebelingbl - I was already doing that up through step 9. I tried the shift and f10 and got a message that said "The current user account is not recognized. Restart the computer and them open user accounts."
  • Cliff Rohner May 11, 2010
    What did you use to test the HD, the ult built into the BIOS or a third party tool? Generally, the login and HD error would be unrelated, unless the SAM on the laptop itself had somehow been corrupted, due to the drive issue. Is this laptop joined to a domain or a workgroup?
  • Brian Ebeling May 11, 2010
    xp or vista?
    Problem Solver:
  • 15 Answers
If you have access to another computer with a cd burner, use can DL a password reset utl, provided that they do not have EFS enabled. Systernals had a good one called ERD that you boot malfunctioning computer up with, they are now part of Mircosoft, but you can still get a 30 trial iso. The new name is Microsoft DART
Posted on Dec 26, 2008
    Scholar:
  • 100 Answers
If frcs68's solution doesn't work try to boot into safemode.
reboot. when bios stuff comes on start tapping the F8 key until it opens boot screen and choose boot into safe mode
after it boots login to administer acount, unless your in-laws added a password to it you should be able to just click on it and enter
if it asks for a password just push enter first.
if that doesn't work then try admin
  • 2 more comments
  • Brian Ebeling Dec 26, 2008
    o.k. hmmm........(Head Scratchin).......Do you have the XP disk?
    well dont get to nervous yet. not gonna format yet :) wanna get to the restore console
    oh yeah. i hope you have the product key, do you?
    1. Place your Windows XP CD in your cd-rom
    and start your computer (it’s assumed here that your XP CD is bootable – as
    it should be - and that you have your bios set to boot from CD)
    2. Keep your eye on the screen messages
    for booting to your cd Typically, it will be “Press
    any key to boot from cd”
    3. Once you get in, the first screen will
    indicate that Setup is inspecting your system and loading files.
    4. When you get to the Welcome to Setup screen, press ENTER to
    Setup Windows now
    5. The Licensing Agreement comes
    next - Press F8 to accept it.
    6. The next screen is the Setup screen
    which gives you the option to do a Repair.
    It should read something like “If one of the following Windows XP installations
    is damaged, Setup can try to repair it”
    Use the up and down arrow keys to select
    your XP installation
    (if you only have one, it should already be
    selected) and press R to begin the Repair process.
    7. Let the Repair run. Setup will now check
    your disks and then start copying files which can take several minutes.
    8. Shortly after the Copying Files stage,
    you will be required to reboot. (this will happen
    automatically – you will see a progress bar stating “Your computer will
    reboot in 15 seconds”
    9. During the reboot, do not make the mistake
    of “pressing any key” to boot from the CD again! Setup will resume automatically with the
    standard billboard screens and you will notice Installing Windows is
    highlighted.
    10. Keep your eye on the lower left hand
    side of the screen and when you see the Installing Devices progress
    bar, press SHIFT + F10. This is the security
    hole! A command console will now open up giving you the potential for
    wide access to your system.
    11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical
    access to your User Accounts in the Control Panel.
    12. Now simply pick the account you need
    to change and remove or change your password as you prefer. If you want
    to log on without having to enter your new password, you can type control
    userpasswords2
    at the prompt and choose to log on without being asked
    for password. After you’ve made your changes close the windows, exit the
    command box and continue on with the Repair (have your Product key handy).
    13. Once the Repair is done, you will be
    able to log on with your new password (or without a password if you chose
    not to use one or if you chose not to be asked for a password). Your programs
    and personalized settings should remain intact.
    O.k. it took me a while to find these instructions. i couldn't remember them. try this and i hop it works for you. Follow the instructions to logon without a password. delete all accounts except administrator.if this doesn't work We'll move onto the next option
    yeah cant do the reinstall repair without the key, so if you dont have it dont do it.
    ok...hmmmm..... do you have the key for the disk?
    Genius:
  • 1,605 Answers
Press cortl+alt+del whneyou have the log on screen
click on option button at eh lower right corner, that will bring you;
login name
password
domain
change the domain to local computer,
login name =admin or administrator,
password= blank, or Admin or Administrator
HP 15 notebook
Something is wrong with your laptop screen.
Is it brand new (under warranty)?
If it is, then, bring it to the store where you bought it and avail the warranty.
Or have it check by a professional technician to fix your screen
Sep 20, 2016 | HEWLETT-PACKARD HP Envy 15-1066nr Notebook
When I turn on my computer there s a blue screen that says I am offline and need to sign in however I do not remember the password I had. It is a HP 2072 a desk to. How can I fix it?
Does it give you anywhere on the screen an option to change user and log in as Guest? If this option has not been activated, you will need to reinstall Windows. You should not lose your data. If you do, freeware tools such as Recuva (after you've reinstalled Windows) should bring them al back. Good luck!
Dec 13, 2014 | HP Computers & Internet
How do I scan a hp laptop
Looks like explorer.exe is taking unusually long to start.
Boot in safe mode and scan the system for malwares. And if you made any changes recently, try un-doing them. Also, update all system files and drivers. You could use the "Windows Update" utility for this.
Aug 28, 2014 | HP Computers & Internet
I cant find my facebook page nor can i delete the on-screen keyboard that pops up every time i log-on. Dont no what i did or if i need RW disks of i may have too many programs on my system ?? Can you help...
Hi, please try this:
1. Press the Windows key/Start key and the U at the same time.
2. This should bring up Utility Manager - Narrator may or may not be automatically running. If it is, close it out (it's a nuisance unless you need it).
3. Select On-Screen Keyboard in the listbox.
4. The option start automatically when I log-in should be checked. Uncheck it.
5.Click OK.
6. Log out and back in and see if that fixed the problem.
I hope this helps.
Thanks for using FixYa.
Sep 13, 2011 | Microsoft Computers & Internet
I down loaded the update 2.1 for my Ti Nspire and applied it to the calculator and now my calculator won't load past the operating systems screen and I can't connect it to my laptop. Please help.
Hi
what you need to do is delete the current OS and load the 1.7 v
if you canot connect the clac to the laptop it needs and hardware reset this can be done only by technician.
if you want to fix the calc let me know
info@ecrdn.com
Mar 02, 2011 | Texas Instruments TI-Nspire Graphic...
Hp pavillion ze 4300-won't start up.
There are a few ways you can get the files off of this to a transfer to a new PC.
  1. Download Hiren's Boot CD and use the mini XP menu to see the files and copy them to another attached drive. On this website use the HTTP link to download the zip file.
  2. Remove the hard drive and attach it to the new PC. The new PC will see the drive and you will be able to copy the files.
  3. Boot to safe mode. Log in as Administrator and copy the files to an external device.
  • As for fixing the Windows OS, use your recovery CD's after you get the data off.
Apr 05, 2010 | HP Computers & Internet
Acer aspire 5630 wont start up. please help!!!
Press F8 key and go into safe mode when u start the computer,tap it a few times until you get the safe mode screen,try choosing "Last known good configuration" and start. If this doesnt work, you can try system restore.
Dec 16, 2008 | Acer Aspire 5630 Notebook
Windows Login Password - Cant Safe Mode or Log in as Admin
Hey Steve/Becky - I have one question for you before I fix your problem. When you booted in safe mode, did it give an option of several logons, i.e.- yours and an administrators?
May 05, 2008 | Microsoft Windows XP Professional With...
HP Pavilion Ze4900 Notebook Logo
723 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
