Question about Samsung SPN4235 42 in. Plasma HDTV
Spontaneously stopped displaying images; screen is just black
TV was working normally earlier in the day.  Later in the day we turned the set back on and it does nothing.  The little red light turns off, we hear the click but it stays black.
    Champion:
  • 217 Answers
TRY THE Y-MAIN BOARD
Posted on Dec 26, 2008
Sony Bravia KDL32XBR9 repair
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 18, 2016 | Sony Televison & Video
Sony KV32XBR400 Video Won't Turn
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Oct 14, 2008 | Televison & Video
DLP HL-R5067W
hi,
The best and the only solution to fix this problem is to call a tech and get it serviced or if it is still under warranty just get it replaced.
Few troubleshooting steps you can try:
1)Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
2)The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck,
Please don't forget to rate the solution
Apr 13, 2008 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Virus or PC problem?
Sounds like a hardware problem. And since your computer is failing like that, my guess is it is the hard drive making that noise. You need to isolate the location of that noise. If it is coming from the hard drive I suggest you back up your data *immediately* using some kind of CDROM based disk imaging software where you can boot to the cd (so you use the hard drive as little as possible). One such program is Image For Linux (http://www.terabyteunlimited.com/image-for-linux.htm)
Jan 26, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Samsung SPN4235 42 in. Plasma HDTV Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
