Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
Disk cleanup does not work
I get the error message "Disk Space Cleanup Manager for Windows has encountered a problem and needs to close." each time I try to run a Disk Cleanup. I never get to "Disk Cleanup"
thank you
  • 28 Answers
There can be alot of reason the program is nt working, more details would help. go here, this can directly solve your prob, you can also download a copy of the prog cleanmgr.exe and replace with the original one in windows directory.(cleanmgr.exe is the actual prog which does disk cleanup) http://www.processlibrary.com/directory/files/cleanmgr/
Posted on Dec 26, 2008
Computer is slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 08, 2013 | Computers & Internet
Tip
How to perform a Disk Cleanup.
Disk cleanup
The Disk Cleanup tool helps you free up disk space by searching your disk for unwanted files and temporary files that you can safely delete without problems. It can remove all of the following:
Files in the Recycle Bin.
Temporary Internet files.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use or wish to use.
To launch the Disk Cleanup tool via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be examined and the amount of space you can potentially free up is calculated and displayed.
The results, showing the amount of space that can be recovered by deleting files a secific type of file that is not needed is then displayed on the Disk Cleanup tab as shown below.
Select the files and click Ok to remove these un-needed files.
Now that a Disk Cleanup has been performed your hard drive should perform slightly faster and have less clutter lying around.
I suggest you perform the disk cleanup tool every once in a while to ensure that your hard drive has a greater lifespan, never has any need to crash or come up with errors caused by unnecessary files, greater performance and increased productivity especially where it is needed most, in the workplace.
on Mar 06, 2011 | Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
My computer is very slow, sometimes freezes or won't load and will not shut down
If your laptop computer won't shut itself down even after you select the "Shut Down" option from your "Start" menu, this means that too many programs are still open on your computer. Before Windows can shut down, it needs to manually close all open software, and having too many programs open can severely delay this process or cause Windows to lock up. Closing these programs will help your machine shut down as normal.
b> Right-click on your task bar. Click "Show Windows Stacked." This will maximize all of the program windows for all open programs on your desktop. The windows will be stacked one on top of the other on-screen. Click the "X" box in the corner of the first window to close that particular program. This will reveal the next program window in the stack. Continue to close these programs until you see your desktop wallpaper again. This, coupled with the fact that your task bar should now be cleared of all program icons, indicates that you have successfully closed all program windows. Your laptop will now shut down normally.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Feb 01, 2013 | Acer Aspire One PC Notebook
Try to load software for microsoft lifecam vx3000 tells me not enough disc space or unexpected problem occured whats going on.
you have low disk space on your C drive
do a disk cleanup
steps
1:Starting Disk Cleanup Disk Cleanup is available on both Home and Professional versions of XP. The utility can be accessed in any of the methods listed below.
  • Click Start | Programs | Accessories | System Tools | Disk Cleanup
  • In Windows Explorer or My Computer, right-click the disk in which you want to free up space, click Properties, click the General tab, and then click Disk Cleanup.
delete unwanted files from My documents ,music folder,recycle bin ,-----------------------------
turn off system restore option
Steps to turn off System Restore loadTOCNode(3, 'moreinformation');
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the System Restore tab.
  3. Click to select the Turn off System Restore check box. Or, click to select the Turn off System Restore on all drives check box.
  4. Click OK.
  5. When you receive the following message, click Yes to confirm that you want to turn off System Restore: You have chosen to turn off System Restore. If you continue, all existing restore points will be deleted, and you will not be able to track or undo changes to your computer.
    Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
you will get at 20% free space after doing these steps
then start the installation again
Mar 30, 2010 | Microsoft LifeCam VX-3000 Web Camera
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
Tip
How to perform enhanced Disk Cleanup on your Windows Operating System
The Windows Operating System tends to collect alot of junk files, programs, and temporary files that you don't need. After a while, these files can fill up your hard drive and slow your computer down.
Anyone can perform the standard Disk Cleanup by right clicking on their hard drive, selecting Properties, and then click the Disk Cleanup button, but who wants to be like everyone else?
To perform a more extensive Disk Cleanup on your Windows Operating System, and to look good in front of your friends, perform the following steps:
Step 1. Click Start and select Run.
Step 2. Type the following in the space provided:
Cleanmgr /sageset:1
Hit the Enter key
Step 3. The Disk Cleanup window will appear. Select all the options, then hit Apply and OK. The window will disappear, but what did you just do?
Well it is relatively simple. The cleanmgr.exe file controls the Disk Cleanup function. The /sageset argument is allowing you to set the options (the selections you made) and the :1 is the value or code you have assigned for the options of Disk Cleanup. But how do we get Disk Cleanup to run using the options we just saved? See Step 4.
Step 4. Click Start and select Run.
Step 5. In the space provided, type:
cleanmgr /sagerun:1
Hit Enter
Step 6. You guessed it. The /sagerun argument is telling cleanmgr.exe to execute value 1.
Step 7. The Disk Cleanup window will appear and begin to automatically perform a cleanup, using the settings you saved, represented by value 1.
Step 8. Do this a few times a week and your computer will stay relatively clean.
Stay tuned for the next Tip as we will setup a scheduled task using this command.
on May 01, 2010 | Computers & Internet
I have a Compaq Presario C501NR 32 bit notebook. My question is how can I use disk cleanup to free up 5.51GB of disk space? What can and can't I delete without messing up my system?
Using disk cleanup will delete temp files, cookies, internet files but that will not be nowhere close to 5.51 GB, you can use disk clean up to remove windows componets as well. You will have to decide what you need and don't use such as games, etc.
Is there a particular reason why you need so much space freed up?
Sep 03, 2009 | Acer Aspire 3680 Laptop
Error message while surfing net
Sounds like U got too much going on. Open the MSconfig - startup tab and uncheck everything, reboot. System will start what it needs to start. Do cleanup then defrag.
Do the above at least once a week.
WinXP sp3 is not available for download. Cleanup Ur machine first.
Mar 31, 2008 | Microsoft Windows XP Professional With...
Internet Cleanup 2.0
Follow the instructions like in this pics and let me know if it was helpfully:
http://www.imagehost.ro/pict/01061853472953ada0f7a.JPG
Oct 31, 2007 | Aladdin Systems Allume Systems Internet...
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
105 people viewed this question
Alun Cox
