Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Sound/power issue Plugging in the power cord, it has to be jiggled to get best quality sound, sounds like speakers are blown until just right, then has to be held. Is this repariable?
  • jpow000 Dec 29, 2008
    I have the same problem. Plugging in the power cord, it has to be jiggled and then there's a spot where it works well. I'm assuming i need a new power cord, but I can't find any seller of this cable.
  • Anonymous Jan 11, 2009
    I tried several ipods but no sound, any suggestions?
I suggest you have the joints inspected where the socket is soldered to the printed circuit board before you buy a new lead as it could be either. Also check the pins in the plug are not distorted. (make sure to disconnect from mains first) regards pcs
Posted on Jan 01, 2009
Bad quality sound
Try plugging into a powered speaker set. The speakers in the laptop are very small.
Nov 15, 2014 | Toshiba Satellite 15.6" C855D-S5230...
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
My speakers keep shorting out would the power cord be a reason?
No, the power cord is not the issue. Tell us more about the symptoms
Oct 14, 2012 | M-Audio Studiophile AV 30 Computer...
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Re: scratchy speaker sound quality
Have you tried with headphones?  Scratchy WITH heaphones. Reinstall driver. If it's NOT scratchy with headphones.  Either your speakers are blown, (which usually doesn't happen), you need to reinstall your sound card drivers, or bad settings.  Double click sound horn. Turn some volumes haflway, or mute sound channels you aren't using. Options Properties will let you show ALL sound properties. Ctrl+S makes the sound properties half size.
ReInstall Drivers: Start - Settings - Control Panel - System - Device Manager, Expand Sound Controllers, Right Click on your sound card, Click Uninstall.  Reboot and reintall.
Might ask to reinstall automatically.  Thats fine.  Install then reboot.  I prefer to cancel the install until I have rebooted.  But both ways tend to work.
Hope you don't have to change your speakers.  Need to pull your mobo to get to em. Instructions here pg. 5-55
James Mac
Sep 08, 2008 | Compaq Computers & Internet
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
NAD CI 9120 (12 Channel)
Check all your cables, not likely but just in case.
Try removing all but two. Left and Right. Does it still happen,
If you can identify the speaker channel try swapping the speaker if possible.
It sounds like one of the speakers has an issue, could be a short in a cross over or speaker coil. If true the speaker is drawing too much current and causes the protect circuit to trip.
Depending on the quality either replace the blown speaker driver or purchase new ones.
If the speaker is not the issue it could be an issue with a power amp. Best to take it in for service.
Mar 19, 2008 | NAD C720BEE Receiver
Possible Blown Speakers?
Any speaker, if abused, can be blown. And if overdriven with dirty power at extreme levels it is not uncommon to burn out the voice coil. You might also want to check out the speaker surrounds. If they go, the speaker works but sounds lousy.
Localize the problem by hooking up two known good working speakers and see what happens. If they also do not work properly or sound like cr-p then the radio is at issue.
Jul 24, 2017 | JBL - MR4W Am/Fm with CD Player White
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
298 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
