Question about Sanyo AVM-3659S 36" TV
Cable channels fuzz out
My older sanyo tv has been having this situation where certain cable channels will go out randomly. It seems like the higher the channel, the more frequently it will go to the fuzzy screen. If we turn off the tv and wait for a couple minutes, the picture will resume like nothing was wrong. Changing channels is hard because you never know if changing back will make the tv go out. This problem never happens when we use the video imput, only when watching cable tv. I'm just trying to decide if this can be fixed, becuase if it isn't worth it, i'm just going to throw the tv away. Any help would be great, thank you.
    Novelist:
    Champion:
  • 236 Answers
I think you have a bad connection in the tuner. The tuner is what decides what channel you get. It's a small box inside your tv about the size of a pack of cigarettes. These have been known to develop loose connections or just go bad. Some are pretty expensive depending on the type set you have. Since your set is older and you want it fixed you'd better get an estimae first. Stargazer
Posted on Apr 23, 2007
SOURCE:
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Sharp tv won't display cable picture (it only shows fuzz) but the netflix and DVD both work. The cable says no input service available. I am able to change the channel on the cable box, but on the tv
Your cable box might not be sending signal out to the tv. Would have to call service provider to have them test your box. Or, you can try unplugging your cable box, and then plugging it back in. Make sure all connections are secure and settings on your tv are accurate. 11_13_2013_3_31_52_pm.png
Aug 11, 2013 | Televison & Video
Sound goes out on random cable channels..only on this tv
It might not be your TV it might be you Cable Provider. Get them to look at your cables in your home
Aug 25, 2009 | Sanyo DP19648 19 in. LCD TV
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Program an old sanyo tv
You need to go into the menu and set it for cable insted of air/tv. The television is only getting the 2 - 13 because on that setting, its as high as it goes.
May 20, 2009 | Sanyo DS31590 31" TV
My sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Mar 22, 2009 | Sanyo Televison & Video
I can't get channels higher than 36 on my tv - attached to cable
some have setings in the menu with an option for tv or cable select cable and try agin
Jan 22, 2009 | Televison & Video
CANT GET CABLE TV SIGNAL
When you hooked up the VCR or the Sat did you use patch cables? Sanyo had a lot of problems with tuners going bad. if you used patch cables you by pass the tuner so it will work
Apr 18, 2008 | Sanyo DS20425 20" TV
TV gets all channels, except 2-6
In most cases when you set your menu ("tuner section") to cable, the tv will pick up all channels, but if you set it to "off air" or "antenna" (or whatever the other choice is labeled), then the tv will only go up to about channel 50 or 60. Are you using cable, dish, or an antenna on top of your house. If using cable or dish, then go into the menu on your tv and set the tuner to "cable". I am pretty certain that your tuner is NOT currently set on "cable" and that also there are no local "off air" channels in your area on 2 thru 6, therefore, you see snow on these channels. I have repaired hundreds of tv's and I feel very strongly that your problem is in your menu.
Keever
Mar 04, 2008 | RCA F31317 31" TV
Can't get cable or any channels
Do you have another TV set you can test the cable with? It possible the TV you bought has a bad tuner. Or your cable line is dead.
Jun 30, 2007 | Sony KV-32V25 32" TV
Sanyo AVM-3659S 36" TV Logo
65 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
