Question about KitchenAid K45SS Classic Stand Mixer
Blender attachment stuck on
The mixer attachment is stuck on. i cannot twist it or push the attachment up (against the spring) to loosen and twist. i've tried soaking in water, thinking some batter or dough might have gotten inside the attachment and dried, but to no avail. it is hard to leverage the attachment without the whole gearhead rotating. Anyway to lock the gearhead?
  • lma_web Mar 28, 2009
    I have the same problem with the pro 6 - flat beater is stuck to the shaft. I'll try more WD40...
    Novelist:
  • 125 Answers
As far as locking the gearhead, no, at least not without taking the planetary off of the mixer shaft. You would have to take the chrome ring loose by prying down gently, and there is a pin holding the planetary to the shaft, a punch would need to be used to drive it out, then you should be able to work it off the shaft and make the whole planetary easier to work on. The only other thing you could do would be to use a penetrant spray, wd-40 or something similar, let it settle into the attachment area, and try some more, sometimes it just takes time, and repeated application to free up.
Posted on Dec 30, 2008
The push in button attachment on is stuck on my kitchen aide mixer
Best you let folks know the model, there is no push in button on the models most of us are familiar with.
Sep 10, 2017 | Food Mixers
How do I attach the A729 to my Kenwood mixer?
Hi,it fits on the blender attachment at the back of the machine.It should twist into place then secure it with the clip that goes over the top.Put on which disc you require,secure with locking nut,put lid on and you should be good to go.Cheers,Carl
Jul 19, 2015 | Kenwood Food Mixers
Kitchenaid difficulty removing whisk
It is not uncommon for gunk batter sugar eggs or other stuff to get up inside the attachment shaft of the mixer and if you don't use it for a while it can turn to glue. remember school flour and water = glue. well add some sugar and some eggs and "wallah" you got glue. How to fix? Get a squirt gun. yep fill it with hot water and squirt it up in the hook and loop portion of the attachment shaft let it sit for 5-10 mins and repeat a couple times. the beater should come off, clean the shaft and then the whisk soak the attachment portion in hot water and let soak to soften the gunk and the spray it out with the sink sprayer. hope that helps. There could be one other mechanical problem and that is the hook that the beaters hang on could be coming out and caused the attachment to jam up ther take a pencil or pen and while pressing the beater up see if the pin wiggles or wobble and most importantly goes back into the mounting shaft. let us know if this helps at all.
Sep 17, 2012 | KitchenAid Food Mixers
Once the blender is attached, how do you start the mixer?
You start it by pushing the switch lever forward, and you need to hold it there for as long as you want it to run. This is a momentary mode and is the only way to run the immersion blender.
Jan 18, 2011 | Braun M880 MultiMix Hand Mixer
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
How to adjust the slicer attachmenton the mixer attachment
take the attc. apart on the back btm of thecutter assy. there is a hand nut loosen shaft should slide either up or down depending on the thickness you want then tighten nut
Nov 03, 2009 | Hobart A200 Stand Mixer
Beater is stuck on the mixer. No leverage when I
Still stuck? It may need to be turn backwards by hand . poswsibly jammed on locking mechanism Try twisting it back and forth. . make sure to unplug.
Oct 26, 2009 | KitchenAid 32685 Mixer
KitchenAid K45SS Classic Stand Mixer Logo
1,282 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
