Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Leaking water under the frezzer - Kenmore 53642 / 53644 Side by Side Refrigerator
  • masipp5929 Jan 03, 2009
    small tray under freezer is full (again)
  • jsillyjaybir Jan 10, 2009
    We have water leaking from under the freezer. It is not a lot of water, but enough to cause a puddle. We have just bought our home and the the refrigerator was included with the house. No manuel was available. We can't find where there is a pan to empty. We can't even really figure out where the water is coming from in the refrigerator.
    Can anyone please advise me?
  • Kenmore Master
  • 528 Answers
The drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr
Posted on Jan 02, 2010
Water runs out the frezzer side when the door is closed onto the household floor.
Look underneath the fridge and check the drain pan it's probably full. Also check your hoses when you under there. You have a line running from the wall underneath the fridge and up to the water supply system. Check for any lines that might be leaking or have come loose and causing the problem.
Dec 22, 2010 | LG LSC26905TT Side by Side Refrigerator
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Water leaking inside freezer and forming ice in the bottom then leaks water out freezer door
you need to clean out defrost drain hole maybe have to remove back cover of frezzer i use a turkybaster with hot tap water to force hole opan
Feb 13, 2010 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Water leaking from left side of frezzer out the
There is a restriction in the condensate drain. You should be able to press a piece of tubing against the drain opening (inside fridge) and BLOW (NOT ****) through the other end. this should clear the obstruction. The obstruction would be slimy goop, sooo again -
NO ****!
Sep 15, 2009 | Jenn-Air Refrigerators
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Jul 31, 2009 | Refrigerators
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maler water leaking
Found that ice had accumulatd in the refill cup that prevented the water from filling the mold so that it spilled over into the frezzer compartment
Mar 25, 2009 | GE Refrigerators
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
Leaking water in fridge.
you will need to check the drain in the frezzer sounds like each time it goes into defrost you will get water thru the vents check the drain pan in the freezer for proper flow
May 10, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
204 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
