Question about Coby DVD-588
Coby DVD-588 This product is NTSC/PAL compatible. The factory setting is set to NTSC. What is the key stroke combination to change the unit to AUTO or to PAL? Any help will be appreciated Thanks KHL
  • Anonymous Feb 19, 2009
    how do i change region codes on this
Found advice and solution on the Internet.
Thanks
KHL
Posted on Dec 26, 2008
Hello bought DVD player that says: multiregion intolerancia Today I realized that multiformat IS NOT The same that multiregion. I need play Pal dvd's so Any one know where can buy one of this. Or in
Where do you live? Different vendors may offer different models.
J&R has the Pioneer DV-610AV-s, http://www.jr.com/pioneer/pe/PIO_DV610AVS/ , region-free DVD player that claims to output to any TV (PAL, NTSC or SECAM) if the unit is in Auto mode. To change the setting, turn off the unit (put it in Standby) and press the Fast Forward button on the front panel (not the remote). Then toggle through the options by pressing ON/Standby (NTSC, PAL and Auto are the options). This unit has a 90-day warranty with J&R. Documentation for the model is available here: http://www.pioneer.eu/eur/products/archive/DV-610AV-S/media.html . Expand the section marked Manuals. It will have a problem with some DVDs created on a computer (UDF) if they are not finalized.
The Panasonic DMR-ES18 PAL/NTSC Region Free DVD Recorder available here, http://www.world-import.com/Panasonic_DMR-ES18_Region_Free_DVD_Recorder.htm , will let you play a PAL format video on a NTSC TV if you add a converter. See http://www.world-import.com/samar.htm for a few ideas.
I hope this helps.
Oct 04, 2012 | Televison & Video
Denon Dvd-2910 only displays black and white on the tv screen
this is not a serious problem. It just has to do with visual compatibility.
Change the DVD display to Pal or NTSC and set that of the TV to Auto or pal.
You might find the PAL/NTSC on the DVD remote, or on the button of the DVD. If it is not there, then Check display settings of the DVD.
As for the TV, Change to Auto or Pal from display settings.
Take care.
Jan 01, 2010 | Denon DVD-2910 DVD Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Coby dvd player 536 only plays movies in black and white
it has something to do with your TV's video system and your player's video system...they should match...that is,PAL-PAL,NTSC-NTSC and etc..or if your tv has a multisystem then just set it to AUTO..
Jun 15, 2009 | Coby DVD-536
Won't play ntsf dvds in colour
if your dvd is ntsc compatable then in your dvd settings menu change from Pal to either auto or ntsc also it might be that your tv needs to be changed in the same way
May 28, 2009 | Televison & Video
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
DVD Player NTSC / PAL inter-compatibility
Appreciate the direct "Ask Me".
Emerson brand is not readily available in my country and therefore we have limited exposure to their various products. Although from what I was made to understand, more often than not, Emerson units are specifically manufactured for the US market and therefore would have limited or no multi region capability. Sorry. Although normally, the NTSC/PAL feature (if ever available) would be clearly marked in the box or in the manual or as a sticker on the unit itself.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | Televison & Video
Dvd player
change the NTSC/PAL setting in your player to auto
Jun 29, 2008 | Bose Lifestyle 28 System
Alpine dve-5207 & tmx-r705
Hi Allan,
To my understanding, both are inter-compatible to either NTSC or PAL.; the player will auto detect what format the disc is and auto-switch over. As the manual says, "DVE-5207 automatically changes the video output signal (NTSC or PAL), according to the disc." On the other hand, the TMX-R705 needs manual settings (2 ways):
1. NTSC and PAL can be directly switched when the DISP on the TMX-R705 remote button is pressed for at least 2 seconds; or
2. On the TMX-R705 remote, press the SETUP button, press the DOWN or UP button within 10 seconds and select AUX 1 SIG. or AUX 2 SIG., press the LEFT or RIGHT button within 10 seconds to set the selection.
Just an after thought, pls verify that your DVD Region number is either 2 or ALL. Additionally, you can verify the color format the unit is using (as well as the disc) by pressing DISPLAY during playback on the player.
Should this not be corrective, perhaps you need to check the grounding/wiring and the interconnections cables.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Nov 14, 2007 | Car Audio & Video
Coby DVD-588 Logo
163 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
