Question about Car Audio & Video
Kicker amp zx1500.1
Are the inside capacitadors expensive on top of one looks like water smudge but its not it hasnt been messed up with water is it burn cus i have to tap my amp really hard....are they expensive....this a 2008 and kant find fuses outside they told me it has internal fuses but they dont look like regular fuses...
any idea
  • 21 Answers
First off if this is a new amp take it back if there is a warrenty.. opening or even turning the external screws void the warrenty. the internal caps and resisters cost only pennies but i would have to suggest that you take it in to be repaired if you dont know what your doing..
Posted on Dec 26, 2008
My one kickers car speaker won't turn on, i replaced the old speakers and put these new kickers 6" speakers. One speakers works but other one doesn't?
try bridging them , first check wires from amp to box or boxes connectors , then check wires inside the box or boxes , then check fuses on amp !
Sep 18, 2013 | Kicker Car Audio & Video
Service light on
You may have blown your amp. It just depends on how hard you run it, and how hot it gets. Check the onboard fuses and make sure they are still good. You can try pulling the heat sink off (the top cover) and look to see if anything is black or burned, even if there is a lot of dust inside the unit. If you got it from a store like best buy you can try taking it there and have them look it over. Places like that tend to have a service tech on hand.
Jul 12, 2009 | Kicker SX1250.1 Car Audio Amplifier
My 96 jetta gets hot & beeps a lot during stop & go traffic
your anti freeze is worn out and corrosion has built up and is clogging/blocking flow, solution is to drain radiator, fill with water and radiator flush (found in auto parts store) follow directions on flush bottle, change thermostat while system is empty and refill with new anti freeze mix. for more detailed help suggest a chilton's manual for your car available at auto store around$25 and guides ou through most repairs
Jul 08, 2009 | 1996 Volkswagen Jetta
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
I think I ruined my ME Super?
Not sure about melting it........ i would be concerned about removing the special coating on the lens. i managed to ruin a digital camera that was tho it was not an expensive one... it still works but the quality of the pictures just isn't the same. be that as it may... use a very clean lint free cloth and a lite amount of water to polish the lens.... it may just be a clouding on the lens that needs to be removed.
Robert
Sep 15, 2008 | Pentax ME Super 35mm SLR Camera
Amp cuts out at certain volume
is the output signal distorted? if not one of the subs could be damaged subs are capable of playing even when damage ,try them 1 at a time to see what happens.
May 17, 2007 | Kicker 04KX350.2 Car Audio Amplifier
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
