Question about Hotpoint Aquarius WF000 Front Load Washer
Washine machine won't turn last spin.
Opened up washing machine and clothes wet. Put back on spin and the drum just rocks (and now at a standstill). Put clothes back on wash and drum is turning its just the last spin. Turned off/on electrics but still not working.
  • Hotpoint Master
  • 3,463 Answers
If it has a Start-Reset button, try pressing and holding for 3 seconds..
Select a drain and spin prog and try again
Plz rate my suggestion.
Thanks.
Posted on Dec 26, 2008
My washer is not spinning clothes dry and the end of the cycle. Everything is soaking wet, what can I do?
is the pump free to spin? when the pump operates(when it spins) is the water getting out? something like a sock may have got past the drum into pipe that joins to pump allowing only some water to escape
Jun 06, 2015 | Bosch Nexxt 500 Plus WFMC5301UC
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Not spinning and making loud noise
Usually when the washer goes into spin cycle, it takes a little time to do so because it is trying to start a heavy load of wet clothes from standstill. As it speeds up, if the load is out of balance, it will start to wobble and then the off-balance switch is activated, shutting down the power to the motor and turning on an alarm momentarily. If this is close to what you are experiencing, try to realign the load so that the clothes are not bunched on one side of the drum - that is, distribute the load around the drum. You should be able to close the lid and press start to get it to try again. If this doesn't work, try removing most of the clothes, especially the heavy items, like jeans or sheets. You might be overloading the washer. Try it again.
Jun 01, 2011 | Washing Machines
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
Dec 29, 2009 | Admiral AW22 Top Load Washer
My washine machine has turned it self off and wont come back on.if you move the drum about it comes on then goes off
Make sure the load is balanced properly in the tub. Most washers have a safety switch somewhere on the tub. If the tub rocks too much it shuts off until the door is opened and it resets.
Dec 19, 2009 | Cell Phones
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
Sounds like your bearings have gone in the back of the drum and damaged your water seal. the clay type substance is possibly water mixed with grease.
Mar 27, 2008 | Maytag MAH6500 Neptune Front Loading...
If the drum spins in the spin cycle, then the belt can't be broken. However, if the drum does not move at all in wash and spin, then the belt can be broken or just fallen off. You will have to remove the back plate and fit the belt back on the drum pulley and the motor pulley. If belt is ok check the motor brushes, they could be worn. They are located one on either side of the motor and identifiable by a single wire that connects to each one. You could also have a restriction in one of the drain hoses which is not allowing all the water to drain out.
Nov 05, 2007 | Maytag MAH6500 Neptune Front Loading...
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
