Question about HP LaserJet M3027 MFP Printer
Touch screen on hp laserjet m 3027 mfp not working
I can't access the fax option and other option cause the touch screen is not working. i can print and copy but can't send fax because the fax option on the panel gray with the sign '' ! ''.
  • jussom Jan 26, 2009
    Same problem, touch screen not responding. Not able to recieve or send faxes. Can copy by pushing the green go button. Tried turning on and off to reset with no luck. There is no actual error displayed on screen just no response.
Turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Posted on Nov 25, 2009
  • rdhpawpaw May 05, 2011
    OH NO!! i could use everything but the email. NOW since i did the calibrate it will not do anything.
How to calibrate the touch screen on hp cm4540mfp
In your Setings, find Display, than Calibrate, and folow the instructions on the screen, or look up in the index of the manual, under Calibration...
Good luck.
Tony :))
Oct 27, 2014 | HP Color LaserJet Enterprise CM4540 Laser...
Copy on HP Laserjet 200 Color MFP
If you just want a single copy of the document, place the page face down on the scanner glass or face up in the document feeder. Then press Copy on the all-in-one (for the M276 this is on the touch screen). If you need to adjust the image quality/size or paper size, press Settings. Then press Image Adjust or scroll down and touch Paper. When done adjusting any setting, press OK. Then press Black or Color depending on your source page.
If you want to scan to a computer first, you'll need to make sure that the full software is installed on that computer. Then launch a scan from the computer before using the touch screen's scan button. You need to set up the default scan options before the scan button works. (There is a monitor program "hears" the button and it needs to know the scan defaults and destinations to launch the appropriate parts of the software.)
Note: many all-ones will not work if there is a problem with the print system.
I hope this helps.
Mar 18, 2014 | HP Color LaserJet Pro 200 M275nw
Looking for a report that says that the faxes have gone please.
1. From the Home screen, touch Administration.
2. Touch Information.
3. Touch Fax Reports.
4. Touch one of the following buttons to print the corresponding report:
? Fax Activity Log
? Fax Call Report
? Billing Codes Report
? Blocked Fax List
? Speed Dial List
5. Touch Print.
For more information, see the fax guide that came with the device.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Mfp 3027 is making a winding noise. i already replace gear kit.
If it is making a wah wah sound when printing, or grinding, the problem is the bushings on the lower pressure roller. Remove the fuser again and check the bushing on the driven side of the fuser. If there is a bunch of dust and you can see a visible gap between the shaft of the pressure roller and the bushing then that is the cause of your problem. If the printer has less than 150,000 pages on it, stop now and do not disassemble anymore of the fuser, see my tip here, as the fuser is covered under an extended warranty by HP. Act quickly though as this warranty extension expires on June 30th.
Jun 16, 2011 | HP LaserJet M3027x MFP Printer
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
How do i Print individual usage report on Hp laserjet M5035 mfp multifunctional Printer.
Usage page
Shows a page count for each size of
paper printed, the number of one-sided
(simplexed) or two-sided (duplexed)
pages, and the average percentage of
coverage.
3. Touch Configuration/Status Pages.
4. Touch Usage Page.
5. Touch Print
Feb 21, 2011 | HP LaserJet M5035 MFP Printer
How do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
My hp 3027 printer cannot boot
Turn off and hold down the 6 key, turn on while still holding 6 until all 3 lights on control panel stay lit. Use the 3 key to scroll on screen until COLD RESET is displayed, then touch 6 again and should reboot. If you are not getting a display at all you need to get a FORMATTER
May 07, 2010 | HP LaserJet M3027 MFP Printer
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Aug 06, 2008 | HP LaserJet M3027x MFP Printer
HP LaserJet M3027 MFP Printer Logo
1,744 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
