Question about Pyramat Sound Rocker Gaming Chair
Ps3 connection i wonder what is the easiest way to get sound from the ps 3 to the chair as i am struggling - no sound at all
  • wickedwinsto Dec 31, 2008
    i have my ps3 conected by hdmi cable to tv. when i connect my chair i get no sound. if i connect my chair to the xbox its fine....
  • chunko Jan 04, 2009
    i have my ps3 connected with an hdmi lead and have tried to connect it to my pyramat pm420w and cant get sound
Connect using the old ps3 lead and put the yellow end into the tv, then connect the white and red leads to your gaming chair. On the ps3 menu go to sound settings and change the sound settings to Av the only way for it to work hope this helps
Posted on Mar 21, 2010
  • sim williams Feb 07, 2013
    the ps3 leads have a different jack to the x-rocker 51231 game chair,
Same problem, if you go through the headset you can get sound but it is all muffled everything was fine until i connected it with the hdmi cable
Posted on Jan 05, 2010
Ive brought a pyramat llc sound rocker s2500 and would like to know how i connect it to my ps3 thanks
Here is a PDF version of the Owner's Manual for your gaming chair:
http://www.pyramats.com/manuals/s2500w.pdf
This will instruct you on how to properly connect the chair to your Playstation 3 console.
Mar 01, 2011 | Pyramat Sound Rocker Gaming Chair
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Dec 02, 2010 | Genius HS-03U Headset
Ps3 problem
- Physically connect the PS 3 to the Belkin router on one of the LAN connection
- Check the connection of the PS3 (if not connecting through)
- Contact your PS 3 manufacturer to gather the ports of the PS 3 and open it on the port forwarding of your router configuration page.
Note: you'll needing to allow the ports of your PS3 and IP address to the Belkin router.
Mar 07, 2009 | Belkin F5D7330 802.11g/b Wireless Adapter
Ps and TV not connecting using av cable
when you turn on the ps3 hold the power button till the system beeps
Nov 15, 2008 | Sony PlayStation® 3 (60 GB) Console
No video on ps 3
Check your HDMI (looks like USB connetion) Connection or your Composite video connection (yellow, red, white connections.) Make sure they are correct and tight on both your TV and PS3.
Most common connection to use 1st is the Composite video connetions. Yellow is your Video display; Red and White are your Sound!
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
Connecting x rocker chair to ps3
I HAVE THE SOLUTION for all ps3 and ps3 slim gamers with the x rocker chair. it took my 2 long hours of frustration but i finally figured out how to make it work with ps3 slim. okay, forget about the red and white audio output plugs, those aren't needed. (my tv has no audio output jacks so i had to find a different solution) find the cable with the green headphone plugs on both sides. plug one end into the tx box and the other into the headphone jack on your tv. make sure your sound settings on your ps3 are set normally so that the sound is coming out of the tv. turn on the tx box, turn up the chair volume (and volume on the tv) and there you have it. enjoy!
PS-III Rock Band - Internet Load While Gaming
Yes, the problem is with the PS3.
When using the PS3, if possible, disconnect any computers and devices (PDA's, PSP's, Phones, etc) that are using the internet both Wireless and Wired.
This should minimize the connections being used.
Another tip is disabling the PS3's Network connection when NOT using the Online features of the PS3. The Ps3 does not have to be connected so that it could be played offline.
Aug 07, 2008 | Video Game Consoles & Games
Aldi tevion gaming chair
i have one of those chairs and you should try getting the red and white cables and plugging it into the chair instead of the mic plug
Jul 30, 2008 | Video Game Consoles & Games
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Pyramat Sound Rocker Gaming Chair  Logo
1,090 people viewed this question
Top Pyramat Video Game Consoles & Games Experts
Michel Laprise Sr
Tom Chichester
Are you a Pyramat Video Game Console and Game Expert? Answer questions, earn points and help others
