Question about Oreck XL2200 Bagged Upright Vacuum
The belt on my oreck xl keep breaking
The belts keeps breaking like it is getting to hot and only breaks half way, enough to keep it from turning.
Thanks, Kathy
  • 281 Answers
The brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Posted on May 04, 2009
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Eureka upright is smoking and blowing air rather than suction
Yes the first thing that I would do is to change the it for a few seconds and then check the belt... if it is hot then you have found your problem...if it is cool then you need to keep looking...
Apr 28, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Belts
Unfortunately this is a very common problem on the Oreck XL uprights. As you you noticed, there is even an extra belt storage on the machine itself, on the bottom plate. When a vacuum cleaner has to put an extra belt on the machine, this should be a clear warning sign that you're going to have replace belts.....frequently! Unfortunately this is just the nature of the beast. Since there is no height adjustment on the nozzle itself, the vacuum will lower until it hits the carpet, the carpet is the only thing that adjusts the height of the carpet attachment. On other vacuums you have the ability to raise and lower the brush head according to what type of carpet your cleaning. When the brushes are at the proper height, the belt is also running at the proper tension and strength on the brush. Since the Oreck doesn't have a height adjustment, the brushes have a lot more resistance to the carpeting, which is what leads me assume that's why the machine goes through so many belts.
Oreck XL's were designed for hotels. Their slogan used to be "The Hotel Vacuum for you Home" even. Anyone who has ever stayed at a hotel knows that most have a very low pile commercial grade carpeting. The Oreck XL does a fabulous job at cleaning low pile carpeting that doesn't have a lot of dirt to vacuum up (restaurants kill most vacuums, but especially Oreck). The problem is that the Oreck XL was originally designed for cleaning low pile commercial grade carpeting, and not to clean plush, piled carpeting. The Oreck's have a 4 AMP motor in them, and where as it's true AMP's don't equal suction power, it's safe to assume that a 4 AMP motor will not produce near the suction as a 12 AMP would. When cleaning low piled commercial carpeting, you don't need much suction power, even an electric broom can clean this type of carpeting.
Oreck however does do one thing right, and that's advertising. David Oreck is everywhere! Newspapers, TV commercials, internet advertising, direct mailers, and more. They spend so much money advertising their vacuum cleaners that everyone is familiar with their products. What most people don't realize is that the customer is the one gets to pay for all of the advertising that's being done! Through the power of advertising, Oreck has taken what should sell for a $100 electric broom, and turned it into a $600 full size upright! Dyson vacuums are the exact same way, a lot of advertising, but not much vacuum behind the price.
Chances are that if you heard about a product through a info-mercial, or a newspaper add, then that product automatically is going to be sell for more then it's worth.
Unfortunately I can't help you fix the problem with your Oreck continuing to burn belts, but I can give you a link to the belts on our site if you need to purchase them. We offer free shipping:
3 Oreck XL® Upright Vacuum Replacement Belts
If you (or your friend) would like a personalized recommendation of a good vacuum specific for your exact cleaning needs, please feel free to add a comment, or contact me, I'd be happy to help.
Chris J.
Apr 21, 2010 | Oreck XL2200 Bagged Upright Vacuum
Burning rubber smell when turned on. checked the belt-is ok.
Take the bottom off as if to change the belt and remove the brush assembly from the VAC. Take the ends off the roller and clean out the string and hair and whatever is wrapped around the end bushings and reinstall. Should free-up the roller Brush and stop the resistance on the belt to motor shaft. Or your belt is streched out and should be replaced, they don't always have to Break to be bad.
Aug 18, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
Why does the belt keep breaking on my kirby
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
May 06, 2009 | Kirby G6 Bagged Upright Vacuum
Oreck xl upright vacuum
Remove the five screws from the baseplate and replace your belt by removing your brushroll, putting the belt over the motor pulley, and then over the pulley on the brushroll, then replacing the brushroll in its original position and screwing the baseplate on. Note that you should make sure that the bearing ends of your brushroll spin freely prior to doing this to avoid the belt breaking again.
Sep 18, 2008 | Oreck Vacuums
Oreck belts keep coming off
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Jan 22, 2008 | Kirby G5 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
1,354 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
