Question about Roper Dryers
Dryer does not heat up
Dyer runs but does not heat up
    Problem Solver:
  • 4 Answers
Usually the first thing to go is the heating element. This is caused by lint build up. Check here first. Be sure to check the circuit breakers. Sometimes one will blow and the dryer will spin on one breaker but not heat.
Posted on Dec 26, 2008
Heating problem
There is a thermal cutoff built into the dryer to protect from fires due to overheating. This could be activating after the dryer starts running for a while. Is it possible that the exhaust duct is clogged up with lint? Check the airflow at the dryer vent.
Dec 17, 2013 | GE DCVH515GF Gas Dryer
DOESN'T HEAT
Could be bad heat element. Lift top of dyer, or look from back side with access panel removed, or look thru door if glass door while dryer is running on a heat cycle. You should be able to see red glow of heat element coming on. If not then you will need to open up dyer and remove drum. Inspect heat element for break in coil or coils touching each other or metal frame of dryer. You can also use an ohm meter and read the restence of the coil ...should be just a couple of ohms.
If it is a bad coil you should be able to replace fairly easy. If it is not coil than you will need to check themistor or cycle control switch. Hope this helps.
Nov 10, 2012 | General Electric DHDSR46EGWW Dryer
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
Dyer is not heating maytag dryer D8000
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Roper Dryer Expert? Answer questions, earn points and help others
