Question about Sony KP-57WS500 57" Rear Projection Television
Full screen has lighter colors on 8 inches on both sides.
8 to 9 inches of either side of screen has lighter colors than in the center of the screen. This is on both Digital or HD and on non-digital Bought the TV from Sears five years ago, just now got HD or Digital
  • Donald Bailey Jan 27, 2009
    I have similar/same problem. Its like the entire screen is a shade darker than the Left & Right edges of the screen (about 8" in). Of course its only noticable when you switch to wide screen. Seems hard to believe all three guns have the exact same problem and are failing the exact same way.
  • 29 Answers
YOU WILL NEED ALL CRTS REPLACED TO CORRECT THE PROBLEM. NOT WORTH REPAIRING.
30 YR SERVICER
APGONZO
Posted on Jan 12, 2009
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
How do you disassemble the Cosco Funsport Play Yard?
Steps to disassemble.1) Pull up on the loop in the center.2) Flip the Funsport upside down3) Pick a side and pull the corners up slightly while pushing the center down. Sides can only move up about an inch.4) Press the release catch in the center of the bar.5) Pull the center of the bar up while holding the release catch in. Sometimes you have to wiggle the catch in and out to get it to release.6) Repeat for each side.7) After each side is collapsed squeeze everything together.8) Place the cover on the floor black side down.9) Put the Funsport on the cover with the plastic corners flush with the edge of the cover. The wheels should be sticking out the bottom.10) Wrap the cover around the Funsport and secure the velcro straps.
May 16, 2011 | Cosco Beatrix Potter Playard Crib
02 Chevy avalanche 1500 need to know torque specs for intake manifold and if theres an tightening sequencing
the torque specs for your intake are the first pass to 44in/lb the second pass to 89in/lb. and the tightening sequence is as follows:
start on the passenger side (right side) the 3rd bolt (from front) is #1 then on the driver side (left side) 3rd bolt is #2 and 4th bolt is #3.Back to right side 2nd bolt is #4 and 4th bolt is #5. Left side 2nd bolt is #6 and 1st bolt is #7. Right side 5th bolt or rear most bolt is #8, left side rear bolt is #9. Then finish with right side 1st bolt is # 10.
Do that the first time at 44 in/lb then same thing over again at 89 in/lb
Nov 27, 2010 | Chevrolet 1500 Cars & Trucks
If a man has 8 balls,and out of eight one ball is lighter than other seven.if he has a balance and had two chances.how will he find the lighter one??
Put 3 balls on each side of the scale. If the scales balance then weigh the remaining 2 balls and this will show the lighter one. If on the first weigh (3 balls each side) the scales do not balance- then take the three ball from the lighter side and put two on the scales (one each side) and keep hold of the remaining one. If the scales balance then you are holding the lighter ball. If not the scales will show which is the lighter ball. You can use the same logic for up to 9 balls.
Jul 06, 2010 | Computers & Internet
How do I install/adjust color lamps on a Hitachi 51UWX20B rear projection tv
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 22, 2009 | Hitachi Televison & Video
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Color is lighter in center of screen. It started as a small bat-man cape shaped area at top of screen and has moved down the center of the screen over the past week. About 5 inches in width and light blue...
sounds like the alignment in the color guns is off. this takes a professional to repair and usually isn't too terribly costly if it's just a realignment. check your local directory for large tv repair.
Jul 11, 2009 | Televison & Video
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
