Question about Gateway EV 500 (White) 15 in.CRT Conventional Monitor
The monitor does not come on, i plugged everything in correctly i think
How to install external monitor to laptop if laptop does not support 15 pin plug from monitor
If your laptop does not have the 15 pin plug (VGA Port) then you will need to get some type of adapter that will make the monitor work. You probably have a DVI monitor.
You just need to make sure you get the correct type of adapter and make sure the ends that plug into the computer are correct such as male or female. For example think of the human male and female body parts when you look at adapters. The vga port on the computer is called a Female port, but the piece that plugs into it is called Male. It's the same with DVI ports.
I think you need a VGA Male to a DVI Female so below is a link to one and for $2.54 from Cable Wholesale.
http://www.cablewholesale.com/specs/dvi-to-vga-cable/30dv-05300.htm
Below is a picture of what it looks like.
Jun 03, 2012 | Dell OptiPlex 780 Desktop Computer 1 x...
No signal everythings plugged in and turned on still says no signal in goes to standby mode.
1. change the VGA cable and test.
2. Plug to another PC or notebook and test.
if still no signal, it might be the display board inside the LCD is faulty.
You need to get a certified technician to fix it.
If cost is higher than 1/3 of a new 18.5" new :LCD monitor; I think you need to think of purchasing
a new LCD already. As new LCD will cover you with 3 years warranty.
take care.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
if the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Aug 02, 2010 | Soyo MT-NI-DYLM2058 Monitor
No audio
FAST YOU CHEAK AUDIO TO ANY HEAD PHONE,THER NOSOUND COMING,SO YOUR MONITOR AUDIO SECTION DAMAGE.
Jul 05, 2010 | Sylvania CL772 17" Flat Panel LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
No signal on monitor
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Jan 02, 2009 | Gateway FPD1975W 19" LCD Monitor
I have a new Dell Studio 540 computer and I'd like to hook it up to my Gateway EV910 monitor. I connected everything correctly. The monitor has power, turns on to the monitor self test screen where it...
You dont need to install a driver for the monitor. The power save mode message appears when the monitor is not able to get a signal from the computer. Make sure the the vga/blue cable is securely plugged to the back of the pc.
note: Inspect the back of your studio. You may have two blue ports where you can connect the monitor, if you do, connect the monitor to the one at the bottom half of the computer.
Jan 02, 2009 | Gateway EV 910 19" CRT Monitor
Monitor
I think your resolution is set too high reduce it in safe mode
Sep 02, 2008 | Dell E153FP 15" LCD Monitor
Emachine 3220
Problem solved by managing to find the installation manual for the motherboard on the PC manufacturers website.
Feb 12, 2008 | E-Machines eMachines Monitor E15T4
Monitor keeps saying self test everything working check plugs
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Nov 13, 2007 | Acer AL1912 19" LCD Monitor
Gateway EV 500 (White) 15 in.CRT Conventional Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
