Question about Lite On Computers & Internet
Dvd rw wont work
I have lite-on dvdrw lh-20a1p but the drivers are ok but i need the device code or a way to reinstall
  • 537 Answers
From the device manager, delete the entry for the DVRW and then reboot or rescan for defvices. You might also check LiteOn's web site for a newer driver. If no luck, see if you can install it in another PC. If no luck there, the unit is just flaky and should be replaced.
Posted on Dec 26, 2008
Lite-on dvdrw lh-20a1p
Please describe the problem that you are experiencing.
Feb 26, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
I have a lite-on "DVDRW
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
dont forget to vote
hope this helps
Feb 05, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
My light on dvdrw lh20 a1p will not read and durnt cd
I was having a problem getting my dvd (Lite-On LH-20A1P) to read my cds. I found a very simple solution that worked for me. I hope the following procedure works for others.
I have windows xp (I believe this solution may work for other window versions)
Go to "My Computer" on desktop (or in Start) and right click on it.
Click "Properties"
On the tabs at the top, click on "Hardware"
Click on "Device Manager"
Click the plus sign beside "DVD/CD ROM drives"
Double-click on Lite-On
On the tabs at the top, click on "Properties"
At the bottom, there is a box that is most likely checked that reads...
"Enabled digital CD audio for this CD-Rom device"
Uncheck it.
Do the same for all DVD/CD Rom devices you may have.
This simple solution worked for me. Now both my DVD and CD Roms are reading all of my cds.
I would suggest trying this simple step first before downloading any drivers or buying any 'Driver Update' programs - which may cause you even more problems than you are already having.
Beth
Sep 14, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
Downloaded windows 7 os and lost the drivers for my lite-on lh 20a1p! how to fix this problem?
If windows 7 does not pick up the drivers on its own then i suggest going onto the website to find them, they normally have driver updates there that should work fine.
Jun 19, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
DVDRW doesn't show Drive in My Explorer.
You may have a virtual drive installed on your PC. (ex: Daemon Tools, Alcohol 120%, etc). If this is the case, make sure they are not set to automatically "mount" or start-up with windows. I had this same problem just today... fixed it by removing the auto-start feature and reinstalling the .CD/DVD burner/
Apr 08, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Lost instalation disk for lite-on liteon 20x ext dvdrw s/n391720400390,model LH 20A1PX500C
You shouldn't need it unless your needing the Nero program that came with it.
If thats what you need will have to contact lite-on to get one.
Here is the web link to get drivers and software if you need it:
http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=75
Select optical storage. Select your model number.
Jun 18, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
LOST INSTALATION DISK
Hi, check here and you will find the drivers you need for your dvdrw. Thanks! /D
http://www.nodevice.com/driver/company/LiteOn.html
Apr 27, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Computers & Internet Logo
98 people viewed this question
Top Lite On Computers & Internet Experts
Gbenga
Victorman
Victorman
Troy Staley
Troy Staley
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
