Question about DeLonghi MG15T SafeHeat Oil Filled Radiator Heater
Lost the manual
We haven't had to use our heater for a few years until now and can not find the manual. It runs for awhile then stops. I am sure it has something to do with the timer dial but not sure what to set the dial on. Any suggestions
  • 70 Answers
It is working properly. It is suposed to go off and on just like your house heater it is thermostat controled the higher the setting the longer it stays on till it reaches a certain tempeture factory preset
Posted on Dec 26, 2008
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
Hi...I have a Toyota DC31 which I have to admit, haven't used for a few years because each time I've used it the bottom row of stitches kept snagging. I tried to slacken the tension but it...
hi, when a machine sit up for awhile, the grease & oil can because nasty, & it needs to have new fresh grease & oil put in it, & also check to make sure there's nothing loose or damaged. so having a machine service at least once a year is good.
if you could explain the problem more maybe I can help you. just send me a comment
Sep 13, 2011 | Toyota Sewing Machines
Good morninng, My Goodman furnace inducer stops and starts at various intervals. At times it runs fine but starts the same issue. Everything starts up accordingly, runs and then the inducer stops for...
Replacing the board, flame sensor, and pressure switch, and cleaning out the induction motor was definitely a good start. Other things to check would be a blocked or restricted flue pipe, I have ran into a few bird nest before!, and you also want to check or replace the hose that runs from the inducer to the pressure switch if you haven't already. To be honest, most of the time I clear out the nipple on the inducer where the hose goes with a small piece of wire and it works. The last thing I would suggest is making sure the new pressure switch is rated for what you need. Alot of the revisions on furnaces actually call for less than the original pressure just for this problem. Hope this helps and good luck!
Feb 15, 2011 | Goodman GMS90703BXA Heater
2006 dodge grand caravan heater only blows warm air when i am accelerating
With the engine cold check the coolant level. Add as necessary. If the coolant gets low enough the first thing to stop working is the heat. Accelerating will push coolant into the void and provide heat until you slow down and then the coolant drains back into the motor.
If you have lost enough coolant to loose heat there is a leak. Some common areas are the rear heater lines under the passenger side of the van, the water pump, and the radiator.
Dec 14, 2010 | Dodge Grand Caravan Cars & Trucks
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
DeLonghi MG15T SafeHeat Oil Filled Radiator Heater Logo
227 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
