Question about LG 42LC5DC 42 in. LCD Television
Aux input help
I added a wii into aux 1 .Now TV say's aux input not available when I
try to switch between tv and wii.Any suggestions
42"
5 Suggested Answers
  • 365 Answers
SOURCE: Wii and PC signals no longer reach TV
try to check the drivers and if necessary reinstall it and look.try to chech the settings and also the connection cables also.thank you
Posted on Dec 27, 2008
  • 8 Answers
SOURCE: haier 42 inch tv says no signal, not available
Your son, or daught hit some button, happend to me too. But i dont remember wat i did. Just try to unplug the tv and plug it bck in
Posted on Dec 23, 2009
eagle338
  • 4889 Answers
SOURCE: i Have a 37LC50CB LG
You will need to get into the installer menu to do this. To activate the installer menu, just press MENU repeatedly until the TV seems to stop responding, then press 9,
8, 7, 6, then ENTER to access the Installer's menu. To remove the Installer's menu, press
ENTER again. When the menu appears, scroll down to item 117 and press enter. 117 is the factory reset and should get rid of the commerical mode.
Posted on Jul 25, 2011
gopakumarg43
  • 75846 Answers
SOURCE: 42" Plasma LG TV stuck on faint white parental screen.
Sounds that the Tuner and Video IF section to your TV has the fault. Seek tech support. This is a highly skilled work.
Posted on Jun 13, 2012
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
How do you connect wii to a sony surround sound receiver
The best solution would be to see if your TV has and aux out for sound. It might also be called audio out. I would look like a red and white jack next to each other by themselves. Then you would take and audio cable and connect the audio out from your TV to the AUX in on the back of your Sony unit. Then select the AUX input selection on your Sony unit to hear the sound.
If you don't have an audio out on your TV then you can plug the red and white cables that go from your Wii console into the AUX input on your Sony unit. The only down side to this is you will ONLY have surround sound and no sound on your TV. Also you will have to pull your Wii cord apart a little bit to reach wherever you will need to plug them.
Please thank me if this helped.
Jan 29, 2011 | Nintendo Wii Console
I have a 1998 zenith color tv and i want to attach a wii. I plugged the video cords to the inputs and turned the wii on and the tv on to aux The wii does not display on the tv. Please...
Are you SURE that you have the wii plugged into the inputs of the tv - red to red, white to white and yellow to yellow? (You would be surprised how many people plug them into the output rca plugs.) Are you SURE that you have the correct aux selection - many tvs of that timeframe have two: a front and a rear. If your wii cable works on another tv (try it if you don't know), then my guess is that your tv is not working right. You could try using an rf converter to plug it into the rf connector (threaded) of the tv and run the tv on ch 3 or 4.
Nov 30, 2010 | Televison & Video
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
There is power to the console. We can hear the
Check the input cables coming from the Wii to the TV. Then check to see that your selecting that right Aux channel. On most remotes there is a source or input selection. Pressing this should cycle through all input channel selections. One input should be the Wii signal.
Bret
1-2-1ComputerServices
Oct 06, 2009 | Nintendo Wii Console
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to www.remotes.com to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
Jan 02, 2009 | RCA Universal Remote Control
I can't figure out the input select
Try leaving the Wii on and switching the TV off then on. I have an old TV and this is the only way I can activate the AUX
However sometimes even this will not work and you have to plug the Wii into a DVD player or Video player then plug that into the Aux to get it to work
Dec 26, 2008 | Nintendo Wii Console
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
No signal on screen in VCR mode
I assume your plasma set has one or more auxillary (component) inputs, and to one of these is where you should hook in the VCR. You will have a video input jack, and a set of audio input jacks (probably 2 for stereo) for each of these aux. input sets. While exact setups differ, depending on your cable box(es), DVD players, and whatever other equip., a likely hookup is from the VCR video & audio outputs to one set of the aux. inputs on the plasma set. When you want to use the VCR for playback, you must select that particular aux. input with the plasma remote. Some of the hookups these days get complicated by all the equip. some have, but the above is at least a start. Thanks
Mar 13, 2007 | RCA VR622HF VHS VCR
LG 42LC5DC 42 in. LCD Television Logo
182 people viewed this question
