Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
TV Would Not Turn On!
I have a Sony Wega 32" that has the same problem Techman showed possible cures for in past replies from other people. The TV all of a sudden just would not turn on. When I try the red light blinks 4-5 times and nothing else occurs. Here are my questions: 1. If I take it in for it to be fixed by a service person how much (US dollar estimate) would it cost to fix? 2. Since Techman stated it is solid state will they be able to replace the part or will they have to replace the whole inside? 3. Although, I am loosing faith in Sony because this TV is a little over a year old and has been used for about 10 hours of use should I insist that they replace parts with only Sony OEM parts? 4. Also, what causes this to happen? I have other appliances plugged into the wall with it and nothing happened to them ie., receiver, speakers.....5. How can I prevent this from occurring again? Thanks!
Don't waste your time to fix it. This is sony design problem. The problem will come again 2 or 3 months after you fix it. Please check what the other people said on Internet.
Posted on Apr 21, 2007
    President:
  • 3,130 Answers
If it is three blink then that is an indication that there is an overvoltage condition and the set shuts down as took much voltage would damage other parts of the TV set, This problem is in the sweep or main power supplys most likely. Probably a regulator IC or a capacitor? If you find an authorized Sony repair center, you will not worry about what types of parts they used, as authorized centers are told by Sony to use only the correct replacement parts. Also this set can be repaired most of the time down to component level. Good Luck
Posted on Apr 16, 2007
Sony WEGA Trinitron SRS BBE 32'
Please reply couple of questions about TV to guess what could be wrong.
1- How many times standby light blinks, there would be interval of 3 seconds in blinks so count pause to pause.
2- Please intimate exact model of TV, written on sticker pasted at back of TV. That will help me to check its schematics.
Hit " add a comment" button to reply.
Thanks.
May 03, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony WEGA
It is TV problem in Tuning section hardware.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron wont turn on.
these sets have a flyback problem, the cure is usually replacement.
If you are unable to replace one, then you will require a technition.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony wega clicks
there are two flat ICs on the main deflection board. they have around a dozen pins or so. the part number is MCZ3001D if you are having problems only at turn on then those are most likely the faulty devices you could take time to figure out which one is bad but just replace both if you had the ambition.
Mar 13, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Black box in bottom of picture
Check your cc mode setting and turn it off(after noting the setting,)if this cures the problem dont use the setting noted above
Nov 11, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony Wega 36fs120 tv
possible bad connect microprocessor circuit. recommend Sony authorized tech assist.
Sep 26, 2007 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
