Question about Curtis CMD5000 DVD Player
Disc does not spin/struggles to spin
The player works once in a while. If it can get the disc going, it will play and work fine for awhile, but partway through the movie it will freeze, and then I have to start over.
  • Daniel Lubbersen Apr 16, 2007
    Read the title. The issue is that the disc has alot of trouble spinning.
    Thanks, but Techman knew what the problem was, thanks anyway!
  • 56 Answers
If the relevant problem only occurs while watching a DVD movie, and everything is fine besides this (i.e. if the device lets you listen to an Audio CD without creating any problem) the problem might be related to the buffer. Because it simply needs larger available space of RAM to use when spinning a DVD compared to a CD. In my opinion, the problem of your DVD player is derived from a buffer underrun state. If I am right, there is nothing to do! Unfortunately, I have to say that if it was a computer , I would easily suggest that you upgrade your RAM. But, sorry..
Posted on Apr 16, 2007
  • dark side
    dark side Apr 16, 2007
    Sorry:) That's as much as I can guess. If you need further support, send it to me:)
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
My Funai WV805 DVD player quit playing DVDs
Hello
If the DVD do not spins inside the playere, this type of fault can occur. Open the top cover of the player and insert a dvd. See whether it spins inside or not. If not, replace the motor that spins the disc inside. This motor is known as Sled motor.
If disc spins inide and the player do not read or play it, replace the Laser Pickup Unit. It is faulty.
Mar 01, 2012 | Televison & Video
Code H02
Your DVD player is having an issue with the spindle motor (the thing that spins the DVD around). The following solution works for most people, and you should only have to do this once.
  1. Unplug the DVD player.
  2. Take the cover off.
  3. Place a disc on the spindle.
  4. Put a little pressure on the disc (so it doesn't slip) and spin it around a few times.
  5. Remove the disc, reassemble, and plug back in.
  6. Try to play a DVD.
  7. Report back if this solved your problem, or if more troubleshooting is needed.
Aug 02, 2009 | Panasonic DVD-S55 DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
Panasonic SA-AK330
Change the spin motor disc
Jun 08, 2007 | Panasonic SC-AK330 Shelf System
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Curtis CMD5000 DVD Player Logo
75 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
